OK......Todays progress. I needed, of course, to remove the old sail. I kept flexing it until it poped off. Thankfully, I didnt put a whole lot of CA on it last time so it came off fairly easy. At this point I realized how much smaller the new sail is compared to the kit supplied one. The new sail will literally fit up inside the old one. At anyrate, the "bump" or raised portion on the deck that helps you locate and secure the old sail would have to go. So with Dremel in hand I cut it out and sanded down the remnants.
Now to fill it in. I have some thick plastic sheet so I laid it over the hole and marked it from underneath. I cut it out and lightly tacked it in place flush with the top of the deck. Some good green masking tape over that, I then poured in some two part epoxy from beneath.
