Bringing my first boat to life again
    • 1936
    Jorg,
    Really enjoying the "Old School" building technique's here! You and David M. sure are helping to keep it alive. Building from scratch at its best. Looking forward to seeing the finished boat. I also like where your shop is located! Great use of space.
    "Firemen can stand the heat."
      • Oct 2017
      • 893
      Thank you, Rob! Yes, finally a real shop! Best are the decent storage lockers.
      some more progress: inserted a styrine spine to lenghten the too short sail and create a sharp edge.glassing and filling to follow...
      Drilling holes for brass rods to attach the stabalizers to the hull.
ID:	186009 Click image for larger version
ID:	186012 Click image for larger version
ID:	186014 Click image for larger version
ID:	186011 Click image for larger version
        • Oct 2017
        • 893
        Look, David! The Bench is messy!!!
          • Oct 2017
          • 893
          At the moment i am extending the "aluminum" section of the stern by 20mm in order to have more space between the screw's tip and the rudder. I want to have a wider rudder, avoiding the cut-out as in the original one making space fo the propeller. Two pvc brackets will connect the stern to the square aluminum spacer that itself will be bolted down to a new pvc intermediate bulkhead that will replace the old abs piece.
          Click image for larger version  Name:	20250214_221150_copy_1148x2040.jpg Views:	0 Size:	52.1 KB ID:	186093 Click image for larger version  Name:	20250214_222910_copy_1148x2040.jpg Views:	0 Size:	52.6 KB ID:	186094 Click image for larger version  Name:	20250214_221153_copy_1148x2040.jpg Views:	0 Size:	46.0 KB ID:	186095 Click image for larger version  Name:	20250215_122251_copy_1148x2040.jpg Views:	0 Size:	58.7 KB ID:	186096
          Click image for larger version  Name:	20250216_114039_copy_1148x2040.jpg Views:	0 Size:	57.3 KB ID:	186111 Click image for larger version  Name:	20250216_114045_copy_2040x1148.jpg Views:	0 Size:	65.3 KB ID:	186112
          And some pictures of the pre-refit tech tray, showing the forward bulkhead with the locking mechanism and the lower compartment that housed the three batteries.
          Click image for larger version  Name:	20250216_085158_copy_2040x1148.jpg Views:	0 Size:	43.1 KB ID:	186098 Click image for larger version  Name:	20250216_085140_copy_2040x1148.jpg Views:	0 Size:	54.2 KB ID:	186097 Click image for larger version  Name:	20250216_085145_copy_2040x1148.jpg Views:	0 Size:	50.9 KB ID:	186099 Click image for larger version  Name:	20250216_085151_copy_2040x1148.jpg Views:	0 Size:	52.0 KB ID:	186100 Click image for larger version  Name:	20250216_085233_copy_2040x1148.jpg Views:	0 Size:	47.7 KB ID:	186101 Click image for larger version  Name:	20250216_085228_copy_2040x1148.jpg Views:	0 Size:	55.4 KB ID:	186102
            • 13446
            Exceeeelleeeeent!
              • Oct 2017
              • 893
              Stern starting to look like a stern again.
              Click image for larger version  Name:	20250217_193224_copy_2040x1148.jpg Views:	0 Size:	64.1 KB ID:	186138 Click image for larger version  Name:	20250217_193230_copy_2040x1148.jpg Views:	0 Size:	57.8 KB ID:	186139 Click image for larger version  Name:	20250217_194127_copy_1148x2040.jpg Views:	0 Size:	53.8 KB ID:	186140
              Quick setup to grind the spacer, it needs to follow the curve of the casing:
              Click image for larger version  Name:	20250217_195220_copy_1148x2040.jpg Views:	0 Size:	54.6 KB ID:	186142
                • Oct 2017
                • 893
                New Bulkhead matched:
                Click image for larger version  Name:	20250221_212654_copy_2040x1148.jpg Views:	0 Size:	63.2 KB ID:	186238 Click image for larger version  Name:	20250221_212929_copy_2040x1148.jpg Views:	0 Size:	63.5 KB ID:	186239 Click image for larger version  Name:	20250221_212939_copy_2040x1148.jpg Views:	0 Size:	63.8 KB ID:	186236 Click image for larger version  Name:	20250221_212737_copy_1148x2040.jpg Views:	0 Size:	50.9 KB ID:	186234 Click image for larger version  Name:	20250221_212833_copy_2040x1148.jpg Views:	0 Size:	54.2 KB ID:	186235 Click image for larger version  Name:	20250221_212839_copy_2040x1148.jpg Views:	0 Size:	54.6 KB ID:	186233
                Click image for larger version  Name:	20250221_212734_copy_1148x2040.jpg Views:	0 Size:	50.3 KB ID:	186244
                Drilling the openings for the steering rods and thinning out to loose some weight:
                Click image for larger version  Name:	20250221_220507_copy_1148x2040.jpg Views:	0 Size:	59.1 KB ID:	186240 Click image for larger version  Name:	20250221_222510_copy_1148x2040.jpg Views:	0 Size:	56.9 KB ID:	186241
                Click image for larger version  Name:	20250221_222518_copy_1148x2040.jpg Views:	0 Size:	59.3 KB ID:	186243
                  • 1944
                  Very cool to see all this work. Thanks for sharing it!
                    • Oct 2017
                    • 893
                    Reshaping of the sail in progress. Need to sharpen the sternward edge a lot more...
ID:	186265 Click image for larger version
ID:	186263 Click image for larger version
ID:	186262 Click image for larger version
ID:	186261 Click image for larger version
ID:	186260 Click image for larger version
ID:	186259 Click image for larger version
                      • Oct 2017
                      • 893
                      A quickly built jig to assist with grinding the sides at straight 90 deg angle. Only adding sandpaper and its ready
                        • Oct 2017
                        • 893
                          • 13446
                          You would have achieved more symmetry if you had assembled the sail blank from two pieces of wood/renshape, glued together in a left-right arrangement. The glue seam on the blank servicing as a never disappearing longitudinal line, top and bottom from which to work the sections.
                            • Oct 2017
                            • 893
                            Yes, thats what id do if id start the sail from scratch.
                            I am just extending an existing pattern... low tech here, symmetrie will be fine when finished.
                            What i need to achieve is this: Sharp trailling edge sternwards, my sail is too blunt and fat.
ID:	186278 Click image for larger version
                            Good to see some handcrafted input in here, David!
                              • 13446
                              Start over. Do it the way I told you. Or continue polishing that turd. You're call.
                                • Oct 2017
                                • 893
                                #30
                                On my way...
ID:	186282 Click image for larger version
ID:	186283 Click image for larger version
