Scratch build Skipjack-conversion : Project 1710 Beluga in 1/63 scale
    • Oct 2017
    • 947
    #106
    Taped the waterline and covered the lower hull.
    Sprayed over with the final dark grey. Mixed up 3 portions black with one portion light grey, single-action airbrush set to very thin until i got a very fine soft spray effect.Cut with nitro-thinner and sprayed over. Time-consuming, very little paint per shot. Of 40ml paint i used 10ml in about 30 minutes.
    Picture no.1 showing first layer to the left and untouched hull on the right.
    Will brush and wipe the upper hull after curing. Edges/rustmarks/aluminum silver on the rails and dome etc. from the detailing were left visible as is a slight streaking on the limber holes as planned.
    I tried to catch that in the pictures. Figured my HD-photos will be SD in here for any reason
    All thats left should be minor detailing...and very little bird poo.
    Comments welcome.
    Click image for larger version  Name:	20241030_105751_copy_2040x1148.jpg Views:	0 Size:	57.4 KB ID:	183804 Click image for larger version  Name:	20241030_105755_copy_2040x1148.jpg Views:	0 Size:	54.7 KB ID:	183805 Click image for larger version  Name:	20241030_105757_copy_2040x1148.jpg Views:	0 Size:	53.9 KB ID:	183806 Click image for larger version  Name:	20241030_114150_copy_2040x1148.jpg Views:	0 Size:	51.4 KB ID:	183807 Click image for larger version  Name:	20241030_114217_copy_2040x1148.jpg Views:	0 Size:	49.6 KB ID:	183808 Click image for larger version  Name:	20241030_114212_copy_2040x1148.jpg Views:	0 Size:	46.5 KB ID:	183809 Click image for larger version  Name:	20241030_114117_copy_2040x1148.jpg Views:	0 Size:	59.5 KB ID:	183810 Click image for larger version  Name:	20241030_114141_copy_2040x1148.jpg Views:	0 Size:	58.6 KB ID:	183811 Click image for larger version  Name:	20241030_114237_copy_2040x1148.jpg Views:	0 Size:	52.9 KB ID:	183812 Click image for larger version  Name:	20241030_114247_copy_2040x1148.jpg Views:	0 Size:	50.1 KB ID:	183813 Click image for larger version  Name:	20241030_114305_copy_1148x2040.jpg Views:	0 Size:	54.2 KB ID:	183814 Click image for larger version  Name:	20241030_114543_copy_2040x1148.jpg Views:	0 Size:	52.5 KB ID:	183815 Click image for larger version  Name:	20241030_114552_copy_2040x1148.jpg Views:	0 Size:	38.1 KB ID:	183816 Click image for larger version  Name:	20241030_114602_copy_2040x1148.jpg Views:	0 Size:	39.7 KB ID:	183817 Click image for larger version  Name:	20241030_114623_copy_2040x1148.jpg Views:	0 Size:	47.9 KB ID:	183818 Click image for larger version  Name:	20241030_114616_copy_2040x1148.jpg Views:	0 Size:	40.1 KB ID:	183819 Click image for larger version  Name:	20241030_114646_copy_1148x2040.jpg Views:	0 Size:	52.4 KB ID:	183820
      • Oct 2017
      • 947
      #107
      Update on painting: Rubbed down the flat grey, dry brushing the rails with aluminum, adding subtile rust and streaking to the floodholes etc. Rust made from red and flat ocre, sprayed over with flat grey on some spots of the hull to reduce the effect. Will wait 'til tomorrow to inspect waterline. I think its right now.
ID:	183850 Click image for larger version
ID:	183833 Click image for larger version
ID:	183834 Click image for larger version
ID:	183835 Click image for larger version
ID:	183836 Click image for larger version
ID:	183837 Click image for larger version
ID:	183838 Click image for larger version
ID:	183839 Click image for larger version
ID:	183840 Click image for larger version
ID:	183841 Click image for larger version
ID:	183842 Click image for larger version
ID:	183843 Click image for larger version
ID:	183844 Click image for larger version
ID:	183845 Click image for larger version
ID:	183846 Click image for larger version
ID:	183847 Click image for larger version
ID:	183848 Click image for larger version
ID:	183849 Click image for larger version
        • 13575
        #108
        Much better. Now you're cook'n with gas!
          • Oct 2017
          • 947
          #109
          Yup! Quite happy with the result. Less K-159...
            • Oct 2017
            • 947
            #110
            Greetings! Am currently finishing the paintjob. Little to none hobby time at the moment, been busy setting up our new garage!
            spraying of the draft marks. Port side using a sticky tape, starboard tried plastic sheet template to safe time. Both need some finalization... Click image for larger version  Name:	20241225_203158_copy_1024x576.jpg Views:	0 Size:	49.8 KB ID:	185003 Click image for larger version  Name:	20241225_203215_copy_1024x1820.jpg Views:	0 Size:	42.1 KB ID:	185005 Click image for larger version  Name:	20241225_203228_copy_1024x1820.jpg Views:	0 Size:	51.3 KB ID:	185004 Click image for larger version  Name:	20241225_203209_copy_1024x1820.jpg Views:	0 Size:	50.0 KB ID:	185007 Click image for larger version  Name:	20241225_203223_copy_1024x1820.jpg Views:	0 Size:	52.5 KB ID:	185006
              • 13575
              #111
              Pen applied draft bars is one method. Custom made water-slide decals another:
                • Oct 2017
                • 947
                #112
                All the draftmarks done! Modified my technique by using the clear plastic sheet as a template to cut out the bars from the tape, i.e. sticking a stripe of tape to the template, cutting out and putting that masking tape on the hull. Results are ok, working time very short. Objective achieved!
                Click image for larger version  Name:	20241228_092333_copy_1600x900.jpg Views:	23 Size:	60.8 KB ID:	185053
                Click image for larger version  Name:	20241227_193545_copy_1024x1820.jpg Views:	0 Size:	64.8 KB ID:	185051 Click image for larger version  Name:	20241227_192359_copy_1024x1820.jpg Views:	0 Size:	57.0 KB ID:	185050 Click image for larger version  Name:	20241228_092119_copy_1600x900.jpg Views:	0 Size:	56.1 KB ID:	185052 Click image for larger version  Name:	20241228_092317_copy_1600x900.jpg Views:	0 Size:	60.8 KB ID:	185054 Click image for larger version  Name:	20241228_092343_copy_1600x900.jpg Views:	0 Size:	61.8 KB ID:	185055 Click image for larger version
ID:	185217 Click image for larger version
                  • Oct 2017
                  • 947
                  #113
                  Done! Next Victim: PAPA SSGN.
                  Click image for larger version  Name:	20250102_204737_copy_2040x1148.jpg Views:	0 Size:	48.9 KB ID:	185192 Click image for larger version  Name:	20250102_205321_copy_2040x1148.jpg Views:	0 Size:	48.4 KB ID:	185193 Click image for larger version  Name:	20250102_210100_copy_2040x1148.jpg Views:	0 Size:	47.3 KB ID:	185194 Click image for larger version  Name:	20250102_205140_copy_2040x1148.jpg Views:	0 Size:	49.8 KB ID:	185195 Click image for larger version  Name:	20250102_204935_copy_1148x2040.jpg Views:	0 Size:	39.3 KB ID:	185196 Click image for larger version  Name:	20250102_205456_copy_1148x2040.jpg Views:	0 Size:	47.8 KB ID:	185197 Click image for larger version  Name:	20250102_204955_copy_2040x1148.jpg Views:	0 Size:	49.6 KB ID:	185198 Click image for larger version  Name:	20250102_205858_copy_2040x1148.jpg Views:	0 Size:	49.0 KB ID:	185199 Click image for larger version  Name:	20250102_205335_copy_2040x1148.jpg Views:	0 Size:	42.6 KB ID:	185200 Click image for larger version  Name:	20250102_210036_copy_2040x1148.jpg Views:	0 Size:	46.8 KB ID:	185201 Click image for larger version  Name:	20250102_210048_copy_2040x1148.jpg Views:	0 Size:	44.6 KB ID:	185202 Click image for larger version  Name:	20250102_205520_copy_2040x1148.jpg Views:	0 Size:	49.0 KB ID:	185203 Click image for larger version  Name:	20250102_205030_copy_2040x1148.jpg Views:	0 Size:	44.7 KB ID:	185204 Click image for larger version  Name:	20250102_205948_copy_2040x1148.jpg Views:	0 Size:	50.4 KB ID:	185205 Click image for larger version  Name:	20250102_205306_copy_2040x1148.jpg Views:	0 Size:	53.7 KB ID:	185206 Click image for larger version  Name:	20250102_205109_copy_2040x1148.jpg Views:	0 Size:	48.5 KB ID:	185207 Click image for larger version  Name:	20250102_205602_copy_2040x1148.jpg Views:	0 Size:	49.8 KB ID:	185208 Click image for larger version  Name:	20250102_205039_copy_2040x1148.jpg Views:	0 Size:	47.4 KB ID:	185209 Click image for larger version  Name:	20250102_205201_copy_2040x1148.jpg Views:	0 Size:	48.0 KB ID:	185210 Click image for larger version  Name:	20250102_204743_copy_2040x1148.jpg Views:	0 Size:	49.7 KB ID:	185211 Click image for larger version  Name:	20250102_204832_copy_2040x1148.jpg Views:	0 Size:	44.8 KB ID:	185212 Click image for larger version  Name:	20250102_205418_copy_1148x2040.jpg Views:	0 Size:	46.8 KB ID:	185213 Click image for larger version  Name:	20250102_205231_copy_2040x1148.jpg Views:	0 Size:	46.9 KB ID:	185214 Click image for larger version
ID:	185216 Click image for larger version
                    • Oct 2017
                    • 947
                    #114
                    Just stepped over THIS:
                    Project 696, unbuilt fast attack ssn. Early 1970s, pumpjet and polymer injectior. Click image for larger version
ID:	186193 Click image for larger version
ID:	186192 Click image for larger version
ID:	186194 Click image for larger version
                      • 1966
                      #115
                      That thing looks bada$$. Love it!
