Scratch build Skipjack-conversion : Project 1710 Beluga in 1/63 scale
    • Oct 2017
    • 1005
    #76
    Final filling and sanding of the conning:
ID:	168982Click image for larger version
ID:	168983Click image for larger version
ID:	168985Click image for larger version
    Imperfections on the limber holes and the gap between docking ring and hull were filled ad brought to shape too.
    The propeller hub received the vortex attenuator, made from 1mm brass, again using the proxxon installation:
ID:	168986Click image for larger version
ID:	168987Click image for larger version
ID:	168988Click image for larger version
ID:	168989Click image for larger version
ID:	168990Click image for larger version
ID:	168991Click image for larger version
ID:	168992Click image for larger version
ID:	168993Click image for larger version
ID:	168994Click image for larger version
ID:	168995Click image for larger version
ID:	168996Click image for larger version
ID:	168997Click image for larger version
ID:	168998Click image for larger version
      • Oct 2017
      • 1005
      #77
      The prop installed into the stern. Stern taper has been further narrowed by hand. Will remove some more material with the machine as the massive grp cone is quite tough!
ID:	169022Click image for larger version
ID:	169023Click image for larger version
        • Oct 2017
        • 1005
        #78
        Put the model on the milling table and ground the stern to shape. Found an air bubble that was filled with ca and carbon powder. Finalized with wet sanding and the screeding tool. The product is well worth that time consumpting process!
ID:	169053Click image for larger version
ID:	169056Click image for larger version
ID:	169054Click image for larger version
          • Oct 2017
          • 1005
          #79
          Hi again!
          Basic scribing of the conning has been re-done. Worked on the safety tracks from styrene rod and tried my approach of an external antenna. Antenna's beeing plugged into the stern endcap, hull halves then closed up. Antenna forms the aft starboard track, reenters the hull at the conning, forms an loop upwards under the conning's ceilling, crosses to starbord and forms the forward port track. To be CA'd down and fixed with epoxy permanently yet.
          Click image for larger version  Name:	20230205_155153_copy_1600x1200.jpg Views:	0 Size:	59.3 KB ID:	169275Click image for larger version  Name:	20230205_153326_copy_900x1200.jpg Views:	0 Size:	47.9 KB ID:	169272Click image for larger version  Name:	20230205_220145_copy_900x1200.jpg Views:	0 Size:	45.3 KB ID:	169273Click image for larger version  Name:	20230205_220136_copy_1600x1200.jpg Views:	0 Size:	53.9 KB ID:	169276Click image for larger version  Name:	20230205_220153_copy_1600x1200.jpg Views:	0 Size:	54.2 KB ID:	169277Click image for larger version  Name:	20230205_220129_copy_1600x1200.jpg Views:	0 Size:	54.1 KB ID:	169278Click image for larger version  Name:	20230205_220304_copy_1600x1200.jpg Views:	0 Size:	50.9 KB ID:	169274Click image for larger version  Name:	20230205_220318_copy_1600x1200.jpg Views:	0 Size:	56.0 KB ID:	169279Click image for larger version  Name:	20230205_220349_copy_1600x1200.jpg Views:	0 Size:	53.7 KB ID:	169280
            • 1939
            #80
            Hi Jorg,
            Very interesting method of doing your receiver antenna! And looking at the final photo showing your WTC can one assume that your ballast system is forward of your electronics WTC? It is really a joy to see others step outside of the so called box and trying different methods of doing there submarine models. Your Beluga is looking great!
            "Firemen can stand the heat."
              • Oct 2017
              • 1005
              #81
              Thank you! Yes, its a sheerline high pressure system, distributed by David Hughes of ZERO BUBBLE MODEL DESIGN. ZB-1 with numerous modifications.
              • Davidh
                • Nov 2010
                • 719
                #82
                Nice work Mate.
                This Beluga is going to be superb!
                Dave.
                  • Oct 2017
                  • 1005
                  #83
                  Thank you, David! The Beluga's lines are special! Will see how it will perform with the refitted ZB!
                  Time for surgery!
ID:	169573Click image for larger version
ID:	169578Click image for larger version
ID:	169580Click image for larger version
ID:	169577Click image for larger version
ID:	169581Click image for larger version
ID:	169576Click image for larger version
ID:	169574Click image for larger version
ID:	169575Click image for larger version
                  Safety tracks are installed, will receive a coat of epoxy after filling and sanding.
                  Jörg
                  • SSBN659
                    • 417
                    #84
                    Your workbench looks a lot cleaner and better organized than mine. I'm very impressed with your work on this boat.
                    Will Rogers
                    SSBN659
                      • 1939
                      #85
                      Jorg,
                      I am still fascinated by what you did with your receiver antenna! Running it outside the boat and utilizing it as a safety tract. I commend you on your forward thinking and ingenuity! As a side note I want to let you know how much I appreciate dentists!
                        • Oct 2017
                        • 1005
                        #86
                        Thank you both! no, this is not my workbench (using two and both are messy) in those last pictures but our kitchentable! That antenna installation is my approch to avoid signal blocking from the carbon hull. We'll see how much of the details are still visible after final priming. I expect more re-scribing. Personally, the propeller is the part i am most happy about. Unbelievable, that not so long ago that hull lay dorment in shards in a box!
                        Jörg
                          • Oct 2017
                          • 1005
                          #87
                          Update: The antenna has been coated with epoxy resin.
                          The driveshaft has been installed. A sterntube with bearings on both ends was glued into the stern cone, ending just after the plane's axis. As the propeller will be permanently fixed to the primary shaft, slots were cut into the underside of the stern to acces the locking collar and the set screw of the universal joint. An intermediate shaft then connects the prop to the engine shaft.
ID:	170126Click image for larger version
ID:	170127Click image for larger version
ID:	170128Click image for larger version
ID:	170129Click image for larger version
ID:	170130Click image for larger version
                          By employing the ZB-1, installation of the dive cylinder was performed similarly to the setup at the MIKE model. However this time, i used a brass standoff spacer to screw down the cradle from PP tube. A socket from resin and glass was formed around it. The stern endcap is secured by two bolts through L-profiles, which were glued in place with an epoxy-carbon powder composite.
ID:	170132Click image for larger version
ID:	170133Click image for larger version
                          The application of adfitional carbon powder prevented the composite from flowing off the brass bars.
                          For the pushrods on this and future models, i made an universal master to cast magnetic couplers, based on an old pen's tip. The mold was made from silicone putty. The casting body is large enough to implement a 2mm bore locking collar with set screw into the resin (if needed) as well as using spacers of different diameter for both thicker and thinner neodym magnets. The first urethane part looks promising!
ID:	170135Click image for larger version
ID:	170136Click image for larger version
ID:	170137Click image for larger version
ID:	170138Click image for larger version
ID:	170139Click image for larger version
                          Jörg
                            • Oct 2017
                            • 1005
                            #88
                            In order to lower someones ,unnamed, blood-pressure, some more "decent" model building:
                            Took the beluga from the shelf and will finally paint it.
                            The hull has been prepared with brushing, soap-washing and rinsing, rinsing with alcohol and applying grey primer. Afterwards, spraying the first coats of lower hull red and upper hull black to check for proper look and to detect the (numerous) spots on the hull that need cleanup, filling and detailing.Figured some scribelines needing to be cut deeper. All done with rattlecans, the "real" paintjob will be performed with thinned colors and the Airbrush.
                            Click image for larger version  Name:	20240630_184839_copy_768x1365.jpg Views:	16 Size:	55.7 KB ID:	181245 Click image for larger version  Name:	20240630_184905_copy_768x1365.jpg Views:	16 Size:	54.5 KB ID:	181246 Click image for larger version  Name:	20240630_184922_copy_768x1365.jpg Views:	16 Size:	52.5 KB ID:	181247 Click image for larger version  Name:	20240630_184932_copy_768x1365.jpg Views:	16 Size:	49.3 KB ID:	181248
                              • Oct 2017
                              • 1005
                              #89
                              More paint work done:
                              All the gaps from the spray paint were closed with said paint and the airbrush. Added a clean white waterline afterwards, which can be found at least in early shots of S-533. After curing, mixed up a basic scum shade and sprayed over, covering the waterline. After removing of the tape, i cleaned up the waterline with 1200' grit paper to make it visible, though wheatered, again. Some cleanup on the surface black, too. Black portion will receive final paint after some sanding of foulty spots and highlighting the scribework with oil paint. Final scum line and some rust will follow, too. So far, i like it!
ID:	183618 Click image for larger version
ID:	183616 Click image for larger version
ID:	183613 Click image for larger version
ID:	183617 Click image for larger version
ID:	183614 Click image for larger version
ID:	183612 Click image for larger version
ID:	183615 Click image for larger version
ID:	183611 Click image for larger version
ID:	183609 Click image for larger version
                                • Oct 2017
                                • 1005
                                #90
                                Tried wiping in aluminum oil paint to the sonar window and the conning railing Click image for larger version
ID:	183633 Click image for larger version
