    • Jan 2020
    • 729
    David, any of those 1.25” SD’s from about six years ago available anywhere? Click image for larger version
      • 12286
      I don't sell stuff anymore.
      However, if you're talking about a SD for the 1/144 Trumpeter KILO, then you're talking a 2" diameter SD. Such:
ID:	149470Click image for larger version
ID:	149471Click image for larger version
ID:	149472Click image for larger version
ID:	149473Click image for larger version
ID:	149474Click image for larger version
ID:	149475Click image for larger version
ID:	149476Click image for larger version
ID:	149477Click image for larger version
ID:	149478Click image for larger version
ID:	149479Click image for larger version
ID:	149480Click image for larger version
ID:	149481Click image for larger version
ID:	149482Click image for larger version
ID:	149483Click image for larger version
ID:	149484Click image for larger version
        • Jan 2020
        • 729
        Yeah David I have a couple of 2” SD’s, want to convert a 1:144 Type Vll, so need a smaller one, lol
          • 12286
          Oohh! I see. That's supper small! Agreed, maybe you can get a 1.25" SD into that Type-7. Tight fit for the 1/144 GATO. I'll help if I can.
ID:	149490Click image for larger version
ID:	149491Click image for larger version
ID:	149492Click image for larger version
            • Jan 2020
            • 729
            Thanks David for the eye candy! Is that a single drive shaft converted to dual with the gears? How do they attach to the prop shafts, I see what looks like tubing, I assume for illustration? Any thoughts on a submarine that would accomodate a 2” that turns sharply? Maybe a boat with the props forward of the planes & Rubber(s). Most seem to be dual props so would need to convert single shaft to dual ising gears.
              • 1152
              Great job.
                • 1152
                [QUOTE=He Who Shall Not Be Named;n149489]
                How do you get your fat fingers in that little cylinder?
                  • 12286
                  Conversion from a single output to two counter-rotating outputs is done with the simple addition of an opposing gear that meshes with the single output shaft gear. Like so:
                  Click image for larger version  Name:	030.JPG Views:	0 Size:	52.6 KB ID:	149504Click image for larger version  Name:	021.JPG Views:	0 Size:	79.1 KB ID:	149505
                  Here you see the only difference with the 1.25" SD motor-bulkhead is the inclusion of the opposing gear to drive the second propeller shaft.
                  Click image for larger version  Name:	DSCN0059.JPG Views:	0 Size:	59.4 KB ID:	149506
                  The soft rubber tubing (silicon or latex) forms a poor-mans universal joint between drive chain elements. However, using this means of correcting for running gear off-set mandates that the thrust loads be absorbed at the after-most bearing points: The shaft strut bearings on the GATO; and the ball type gimbal on the Disney NAUTILUS.
                  Click image for larger version  Name:	DSCF4353.JPG Views:	0 Size:	64.1 KB ID:	149507Click image for larger version  Name:	044 (3).JPG Views:	0 Size:	79.4 KB ID:	149508Click image for larger version  Name:	042.JPG Views:	0 Size:	79.7 KB ID:	149509
                  That little KILO turns just fine! https://youtu.be/oc4XLg79QDI
                  Don't over-think this project!
                    • Jan 2020
                    • 729
                    Thankyou “my lord”, invaluable information! The photos with your descriptions always tell the story, even for numb nuts like me!
                      • Jan 2020
                      • 729
                      So my 1:144 Kilo Pool Trials went well on surface maneuvers, however, ballast pump was inoperable. Upon my return to my shop I found that my Tx settings had been changed. I mapped my ballast channel five to switch C. Somehow that got changed…..grrrrrrr. Will return for pool runs in 10 days.
                        • Jan 2020
                        • 729
                        David, silly but I cannot figure how the second driveshaft with the opposing gear is anchored to the endcap? Hooe this makes sense.
                          • 2749
                          Hi Biggsgolf.
                          Just want to ask your about your KILO WTC. AFAIK, you're the only one who has used the RCshipyard WTC. How is the motor output shaft sealed?
                            • Jan 2020
                            • 729
                            Hi, its a shaft seal installed from inside of endcap.
                              • 2749
                              Shouldn't it be on the outside of the endcap with the open face of the seal to the water so that as the sub goes deeper increasing water pressure presses down on the seal causing to seal better ?
                                • Jan 2020
                                • 729
                                I hear you on that, I believe the motor face creates a union with it where it will not lose the pressure seal.
