  • DrSchmidt
    • Apr 2014
    • 1357
    After finishing my VIIc build I decided that I need another cut-away challenge. So I'm going for a 1:35 XXIII boat based on the excellent Bronco kit. Minor problem....the model has no interior. So I'll make it myself. Started designing everything within the CAD, based on books, plans, and photos. Firts impression....drivetrain with stuffing box, thrust bearing, belt drive-coupled creeper motor, main clutch, e-motor, Diesel clutch and the MWM RS32S Diesel. Tedious, but the first fitting in the virtual pressure hull only required minor corrections. Good sign...Click image for larger version
Name:	Screenshot 2019-12-28 at 15.58.39.jpg
    • 13831
    I'm so looking forward to this project, Doctor. Always good stuff from your work-bench.
    • DrSchmidt
      • Apr 2014
      • 1357
Name:	Screenshot 2019-12-30 at 14.09.08.jpg
      Hull strcuture and electric switch panel done...getting cramped in there.
      • DrSchmidt
        • Apr 2014
        • 1357
        Oxygen bottles, compressed air bottle, Diesel exhaust valve, electric cooling water pump added...
        • DrSchmidt
          • Apr 2014
          • 1357
          Added the blower for the room ventilation. Here starts the guesswork because plans and descriptions are not clear about position and size. Also added the first sketch of the air induction and the air exhaust masts. Again, plans are not coherent...again, some room for guessing.
          • DrSchmidt
            • Apr 2014
            • 1357
            Added the blower for the room ventilation. Here starts the guesswork because plans and descriptions are not clear about position and size. Also added the first sketch of the air induction and the air exhaust masts. Again, plans are not coherent...again, some room for guessing and painfully slow reconstruction from some bad photos....nevertheless, getting there:
            Click image for larger version  Name:	Assembly-4.jpg Views:	0 Size:	78.2 KB ID:	135918
              • 3705
              I found this photo
Name:	Type XXIII.jpg
              Maybe of help?
              • DrSchmidt
                • Apr 2014
                • 1357
                Awesome.....THX. That's U-Hai (S-170), an overhauled Nazi sub that was used as training boat for the post war German Navy....
                The Diesel air-intake had been re-dedigned. So this might not be the actual XXIII configuration. But it gives good hints!
                • DrSchmidt
                  • Apr 2014
                  • 1357
                  But actually, this photo helps allot understanding the drawings!! Tank you again.
                  • DrSchmidt
                    • Apr 2014
                    • 1357
                    The new photos of the induction masts booked me into a complete redesign of the masts and the respective piping. Again, allot of guessing, but the green pipes are according to the ventilation plan and comply with the pics...tedious.
                      • 2012
                      Holy hell... This is going to be an amazing model, when completed, digital or otherwise!
                      • DrSchmidt
                        • Apr 2014
                        • 1357
                        The current status with added diesel airbox....
                        • Kim Sleep
                          • Nov 2013
                          • 329
                          HOOOLLLEEE Mackarel!
                          • DrSchmidt
                            • Apr 2014
                            • 1357
                            More detail work. With the help of the iron plan of the Type XXIII I added the machine bases and floor. On the starboard side, benath the floor plates and parallel to the Diesel was the lubricating oil tank.
                              • 2548
                              If you're planning on printing this, it'll probably pay you to buy your own printer with the price of them these days, versus bureau costs.
