    • 1393
    #46
    Induction masts, Schnorchel, direction finder and below the control room. I also started to lay out the lower structure: drinking and waste water tanks, storage and ammo compartments and below the regulating tanks.
      • 1393
      #47
      Slowly coming together. Added the vent valve for the central ballast tank, the exhaust line to the Schnorchel mast and more detail in the regulating ballast tank...
        Excellent work and detail.
        • SteveT44
          • Feb 2011
          • 5
          #49
          Impressive work!
            • 1393
            #50
            Working on the Schnorchel drive. An air motor drives via a bevel gear a reversing gearbox (modeled after a Volvo Penta gearbox). After latter, another bevel gear drives the shaft to the Schnorchel gear. In between a chain drive for manual operation in case of failure of the air motor...took me while.
              • 1393
              #51
              Working on the breech doors of the 533 mm torpedo tubes of my Type XXIII submarine project.
                • 1393
                #52
                Torpedo room taking shape...
                  • 3769
                  #53
                  I believe the torpedoes were loaded from the outside. With that in mind, would it still look the same on the inside as other subs that loaded the torpedoes from the inside?
                  Other than thinking out loud, Love the work you are doing on this.
                    • 1393
                    #54
                    Here's a rare picture of the inside of a Type XXIII. The toredo tubes were taken from canceled VIIc boat builts. So exactly the same like on other German boats. But you are right. Tehy were loaded from outside....
                      • 3769
                      #55
                      Wow! Great photo! Thank you for sharing that.
                        • 1393
                        #56
                        So, the crank interface for the muzzle dor ins on, the end of the firing rod, the director valve and some bits and pieces....not even halfway through.
                          • 1393
                          #57
                          Damn those things were comolicated with all the mechanic interlocks....
                            • 1393
                            #58
                            And some more valves and interlocks....
                              • 3769
                              #59
                              I am tired of posting WOW. So, if I remain silent, just know I am saying that every time you post a photo. I love what you are doing.
                              • Scott T
                                • May 2009
                                • 414
                                #60
                                Very Nice !
