    • 1393
    That's exactly what I'm planning to do....
      • 1393
      The creeper motor support.....elegant solution they found back then:
        • 1393
        Working on the toilet...a special one that was emptied using compressed air.
          • 1393
          Click image for larger version  Name:	Screenshot 2020-01-25 at 17.11.24.png Views:	0 Size:	97.2 KB ID:	136325Found a basic drawing of a Dräger circulating blower. This is one installed in a Type IXc, but similar ones were also installed in the XXIII boats.
            • 1393
            Puzzle work....the rudder works via a thread drive. The respective crank rods are a pain to fit in. Had to re-design the ventilation tubes more than one time.
              • 1393
              Added the stern hydroplane drive. Again a rotating shaft drives a gear that re-directs the rotation downwars by 90°. A threaded drive then translates the rotation into an up and down movement that is then re-directed via a deflection lever towards the plane itself....tricky.
                • 1393
                Started experimenting with my new 3D printer. Some t-frames for first fitting tests. Quite pleased with it...
                  • 1393
                  Started priniting the parts for the Diesel. Took me some time to get the motor block right, but getting there.
                    • 1393
                    Diesel is taking shape. Quite pleased with the quality of the 3D-printed parts...
                      • 13986
                      That picture of the engine makes it very clear: the machines make model parts better than any human hand could. The ghosts of the Krell beckon!
                        • 2641
                        Dave's Id monster is about to go on the rampage. Cue eerie electronic sounds from the Barron's.
                          • 3759
                          No, Bob will replace David with AI technology that will mimic David's responses. David will become like the (old) show Max Headroom. He will live forever!
                            • 1393
                            Fuel lines and the pusch rods for the rocking levers....tedious.
                            • Kim Sleep
                              • Nov 2013
                              • 329
                              Holy Crap...that is truly amazing!
                                • 1393
                                #30
                                Oil, fuel, and cooling water pumps, rpm-meter, cooling water lines to the cylinder heads and the motor block, and of course the exhaust. Small stuff...
