November Holiday
    • Oct 2017
    • 975
    #91
    Thank you David and Fredrik. Maybe i did not express myself correctly. I know how the flaps/covers work, but i do not know if they were open when the boat operated submerged the way you can see in the pictures of the surfaced vessel. From the Mike, Charlie etc. I know the covers would split open, the plane would extend and then they would be closing, only letting the plane shaft pass through a circular opening. I believe the flaps should be closed when the bow planes are extended, and they are simply open in the pictures to prevent jamming in case there would be ice on the mechanism in arctic waters.
    Jörg
      Thanks for the input men. Tom; I hadn't thought about making a socket for the sail because I already have a constant, level hard deck to work off. The vearios versions are different lengths and widths as well. Might get a bit complicated. I'll take the Master's advice and cast it up as a separate bit with the flange incorperated.
      Lots of good (and previously) unseen photographs from Fredrik overnight as well. Thanks Mate - really appreciated. It amazes me that people can find these things in the mose obscure corners of the net.
        • 13597
        #93
        And I too applaud Fredrik's excellent work finding that picture of the bow plane shutters -- solid gold! And Fredrik: any shots of the bow plane that detail its trailing edge 'flap' (I believe, like the later SIERRA's that the bow planes were variable geometry in function), and maybe even the look of the drag-link that operated the flap.
        Now that the sail will be a separate piece it makes it much easier to incorporate a proper mast foundation to insure all the vertical stuff stays parallel to one another. Good call, Scott.
        Good stuff guys! You all are putting the fun back into this game.
          This is the only photograph that I have of a working drag hinge.
Name:	drag hinge.jpg
          • DMTNT
            • Jun 2018
            • 297
            #95
            Adding to what David said, I kept the sail on my Jimmy Carter detachable. I epoxied a brass nut into the inside of the sail, and secure it onto the upper hull with a screw and. washer inserted from the bottom. It holds very tight and allows not only easy & direct access to the air induction system, but also the ability to fit the boat with a differently configured sail. I realize that second point is more of a novelty, but still. I appreciate having that feature.
            -Brady
            Dead men tell no tales...
              • 13597
              #96
              Holy Crap! That's perfect. A SIERRA?
                • 651
                #97
                This looks good. I was toying with an idea for one of rhese and bought a small plastic kit of one, was only about 6” Long. Assembled basic hull to use as a guideline and thought, no way! But seeing this coming together is a whole different fish
                  There's no great technical explination for what is happening right now with this build. I'm checking dimensions, adding or subtracting filler and sanding. Getting the walkways and the top deck symmetrical and tapered; confirming the rear geometry and casting up a set of rear planes from the Renshape master. Thus;
                  • DMTNT
                    • Jun 2018
                    • 297
                    #99
                    Just fabulous.
                      Not yet. But it might be. The great difficulty right now is that there are no accurate plans. I'm making this thing in accordance with a flawed depiction. Its very frustrating and more so because I KNOW that as soon as I finish it, a set of real, dock yard plans will turn up to highlight all of the stuff ups that I have made.. Bugger!
                        • Oct 2017
                        • 975
                        #101
                        some more pictures:
                        Все, что с ними связано: фото, чертежи, описание, истории...: Вот есть фотораздельчик: http://www.balancer.ru/_cg/_st/s u/... [image link error] Фотографии подводной лодки 627 и 627а проекта ::… (стр. 1 из 19)
ID:	130432Click image for larger version
ID:	130451Click image for larger version
ID:	130433Click image for larger version
ID:	130434Click image for larger version
ID:	130435Click image for larger version
ID:	130436Click image for larger version
ID:	130437Click image for larger version
ID:	130438Click image for larger version
ID:	130439Click image for larger version
ID:	130440Click image for larger version
ID:	130442Click image for larger version
ID:	130441Click image for larger version
ID:	130452Click image for larger version
ID:	130443Click image for larger version
ID:	130444Click image for larger version
ID:	130445Click image for larger version
ID:	130446Click image for larger version
ID:	130447Click image for larger version
ID:	130448Click image for larger version
ID:	130453Click image for larger version
ID:	130454Click image for larger version
                          • Oct 2017
                          • 975
                          #102
                          some more pictures:
ID:	130457Click image for larger version
ID:	130458Click image for larger version
ID:	130459Click image for larger version
ID:	130460Click image for larger version
ID:	130461Click image for larger version
                            • Oct 2017
                            • 975
                            #103
                            and more...
ID:	130464Click image for larger version
ID:	130465Click image for larger version
ID:	130466Click image for larger version
ID:	130467Click image for larger version
ID:	130468Click image for larger version
ID:	130469Click image for larger version
ID:	130470Click image for larger version
ID:	130471Click image for larger version
                              • Oct 2017
                              • 975
                              #104
                              and some more... Click image for larger version
ID:	130475Click image for larger version
ID:	130476Click image for larger version
ID:	130477Click image for larger version
ID:	130478Click image for larger version
ID:	130479Click image for larger version
ID:	130480Click image for larger version
ID:	130481Click image for larger version
                                • Oct 2017
                                • 975
                                #105
ID:	130487 and some more... Click image for larger version  Name:	25-4299915-image1zfodnok.jpg Views:	4 Size:	117.9 KB ID:	130484
                                Click image for larger version  Name:	25-4299933-imagegewvse60.jpg Views:	4 Size:	140.8 KB ID:	130485
                                Click image for larger version  Name:	25-4299911-image-5-.jpg Views:	4 Size:	426.8 KB ID:	130486
                                Click image for larger version  Name:	25-4299927-image7uy9mata.jpg Views:	4 Size:	377.3 KB ID:	130488
                                Click image for larger version  Name:	24-5314441-83-86-petrov-copy.jpg Views:	7 Size:	98.1 KB ID:	130489
                                Click image for larger version  Name:	21-3319750-img097.jpg Views:	1 Size:	117.2 KB ID:	130490
                                Click image for larger version  Name:	19-5621205-k-3-leninskij-komsomol-.jpg Views:	2 Size:	80.7 KB ID:	130491
