. Bill Bibeault Bronco Type XXIII Build
    • 13982
    #121
    Originally posted by cgbillb
    Tom and David thanks for all the help om my U-2326 build
    Less groveling.
    More assembly.
    Damnit!
      • 2640
      #122
      1.124" inside diameter, Andy.
      Bit small. But I think this one will just about go- https://www.banggood.com/Mini-Smalle...r_warehouse=CN
      • cgbillb
        • May 2018
        • 182
        #123
        Thank you Andy, I am not going to put a camera on the U-2326, but will add one to my U-505 so I saved that information, but now I have to go work on my U-2326 not allowed to chat.
        Again thanks
        Bill
        • cgbillb
          • May 2018
          • 182
          #124
          Before I screw the frames up big time, and there is no information in the RTFI does this look right, if so great, Tom drill a 1/8 in hole for the alignment screw,
          I did not have too it fell into the 1 inch hole exhaust hole
          again is this right?
          Bill Click image for larger version
ID:	128302Click image for larger version
            • 3754
            #125
            No issues Bill. Looks good!
            • cgbillb
              • May 2018
              • 182
              #126
              Thanks Tom I will glue it in
                • 13982
                #127
                You put the tabs in backward.
                Moron!
                • cgbillb
                  • May 2018
                  • 182
                  #128
                  yes I know after I saw a photo of yours trying to remove them as we write
                    • 13982
                    #129
                    Just a minor road-bump. Carry on, sir.
                    • cgbillb
                      • May 2018
                      • 182
                      #130
                      Yes David your right just like life, I broke one tab taking it off so I put that task aside for now, working on Conning Tower to I figure out how to fix my tap problem,
                      I may need to cut them all off and do something different Wine time HaHa
                      • cgbillb
                        • May 2018
                        • 182
                        #131
                        I just put the two hulls together a couple of times in fact and they go together great , have some more sanding and final touches to do, but works ok
                        So I am going to leave it for now, the taps being backwards that is and move on
                        I tried to get into your web site but does not load up, is it still active? Got the address from one of the post.
                        Bill
                          • 13982
                          #132
                          Bill
                          I don't have a web-site of my own. When I was D&E Miniatures I did, but that was a long time ago. This is where I hang out.
                          • cgbillb
                            • May 2018
                            • 182
                            #133
                            OH ok how about at SubCom you hang out there
                              • 13982
                              #134
                              I check out the board, but don't participate. We had a falling out with the leadership over there about a decade ago.
                              What was the last worthwhile WIP thread you saw over there? Entropy has caught up with that bunch.
                              I build. They talk. I teach. Most of them have not advanced past the techniques and gear I developed and applied to this hobby in the 90's.
                              You may have gathered by now, Bill -- I don't play well with the other children.
                              • cgbillb
                                • May 2018
                                • 182
                                #135
                                What do you mean for as old guy you play good, ok I was asking because I I want to build my U-505 , after MY u-2326 IS IN THE WATER , WHERE YOU HANG OUT
                                Which will be here then. back to sanding don't have time to chat all day
