. Bill Bibeault Bronco Type XXIII Build
  • cgbillb
    • May 2018
    • 182
    #31
ID:	128124Click image for larger version
ID:	128123 OK this is a test email photos from my cell to my laptop down loaned all photos
    • cgbillb
      • May 2018
      • 182
      #32
      David I have tried to separate the hulls this way, the way Bronco makes them, have you tried this way before , this is the wrong WTC just for test
      Bill
        • 13841
        #33
        Bill
        No, Bill, I have not tried that -- on anything. Dumb move. RTFI!
        • cgbillb
          • May 2018
          • 182
          #34
          yep who would do that HahA thanks
          • cgbillb
            • May 2018
            • 182
            #35
ID:	128131 Here you can see that I used West System Epoxy to secure the Propeller shaft stern tube assembly Bill
              • 13841
              #36
              Good, clean work. And it looks like you resolved the photo issue, Bill.
              • cgbillb
                • May 2018
                • 182
                #37
                I think I did David we will see my photos may have been to large about to glue the hulls together
                • cgbillb
                  • May 2018
                  • 182
                  #38
                  Here I glue the two hulls together with Plastruct Plastic Weld goes on with a small brush . Make sure you snap the half's together all along the keel and deck, let sit over night Click image for larger version  Name:	24.jpg Views:	1 Size:	154.8 KB ID:	128136
                  I did not take photos but I installed the rudder and the rods for the bow and stern planes,will take photo when I cut her open tomorrow
                  • cgbillb
                    • May 2018
                    • 182
                    #39
                    Here you will see the glue and Epoxy that I used for the hull and Stern tube assembly
                    Yes David have my photo problem fixed was just too large of a file Click image for larger version
                      • 13841
                      #40
                      Tom put you straight on the photo-size issue -- took me months to figure that out.
                      Only use the cohesive cement on styrene to styrene unions, Bill. You get a proper fusion (weld) between the parts with that. And use stretched sprue and styrene strip as 'welding rod' to melt within and fill any significant gaps between parts being glued together.
                      And scrub all the plastic parts with scouring powder and water followed by a good rinsing. The injection forming process leaves oil on the parts surfaces and that will bugger up bonding and painting.
                      • cgbillb
                        • May 2018
                        • 182
                        #41
                        Great thank you David
                          • 1613
                          #42
                          For what it's worth, i still can split my type XXIII into four parts, but the easiest way will be cutting at the waterline, you still need tools to open her up, don't have that problem with mine
                          • cgbillb
                            • May 2018
                            • 182
                            #43
                            Manfred
                            Thanks did it last night photos will follow
                            Bill
                            • cgbillb
                              • May 2018
                              • 182
                              #44
                              Question: what is the best type of glue to use for PLA, I did RTFI, just wondering what boat modeler's use.
                              Printing a stand for my U-2326 as we write. The first one did not come out very good, used super glue .
                              Bill
                              • cgbillb
                                • May 2018
                                • 182
                                #45
                                Here I set up my boat on a board, and marked my lines Click image for larger version
ID:	128146Click image for larger version
ID:	128147Click image for larger version
