Zulu
    No problem. 2" sounds fine to me (since I know no better). Thanks for the feed back too. I'm happy that its an improvement on the last one. Slowly, slowly.
      • 13575
      #122
      These shots will demonstrate what we have in the way of the SD for your fine looking ZULU:
      In the hull is a 2" diameter Lexan tube, off-hull is a 2.5" SD
      See how high out of the water (in surface trim) the 2.5" cylinder is? Yuck!
      Here's the 2" SD cylinder -- its top just about even with the designed waterline. This is more like it!
      Ready to start 2" SD fabrication, Scott. Waiting to hear from you. Note the three gears on the upper, right bulkhead -- that's how I'll get three outputs from one input.
      The single-shaft 2" motor-bulkhead to the right illustrates how your get your unit: servos and pushrods installed. Before it gets out of here it will be tested for water tightness and function. All you'll have to do is populate the SD with the usual devices and non-sense.
        That makes perfect sense. I'm really looking forward to seeing this thing and getting it installed. Can't wait.
          • 13575
          #124
          OH!? .... explain it to me then, I don't have a clue!
            Form an orderly cue... all those who have a clue to the back; those without, take charge!
              Fitted the fore and aft safety lines and the rear antenna support.
              • bwi 971
                • Jan 2015
                • 940
                #127
                Not really Zulu but its filling in the time between Zulu tasks - the new tail for the Delta III.
                Much better mate......think you are infected with the “rivet counter” microbe.
                grtz,
                Bart
                "Samuel Smiles"
                • bwi 971
                  • Jan 2015
                  • 940
                  #128
                  Just mentioning this by the way?
                  You know your gears sir....it's not so simple to get it the same as the original regarding rotation of the propellers.
                  This is really nice.....am I right assuming you are going to align the PS and SB output shaft in the horizontal plane and offset the central one horizontally (down) and vertically (to PS)?
                  Grtz,
                  Bart
                  "Samuel Smiles"
                    I'm definately infected...with Bartitus! I was thinking the same thing about the shaft rotation and wondering how we were going to get counter rotating outer props.
                      Hummm..... we might be wrong. Maybe the two gears at the top are meshing together and one is driven by gear at the bottom. Then we flip the bulkhead around to place the two side by side gears toether and we have... THE ANSWER!
                        • 13575
                        #131
                        You two are making this harder than it has to be (Foreigners!....).
                          • 3429
                          #132
                          Nice build.
                          I'm too lazy to scan all the threads might as well go and ask the man himself. "Can you give me a list of all sub hulls you've made so far?"
                          ​​​​​​​regards
                            Sure. Uniform, Piranah, Romeo and Zulu. Working on a new one right now.
                              • 3429
                              #134
                              ZUPR ( Super!)
                              (your inbox was full so instead of a PM i posted my query here)
                                • 13575
                                #135
                                Nice build.
                                ​​​​​​​regards
                                Who are you asking? If me -- only a few I built, the rest I assembled from kits.
