Victor III
    • 13997
    #91
    That first picture suggests the boat would look great with an an x-tail configuration. Not scale, but I bet it would a hoot to drive, especially with full flying control surfaces. Crossfire-Beluga!
    Yeah, Andy. They called it, ALBACORE phase-3
      #92
      When I don't like it, I kill it.
      The creeper shafts were not perfect as I wanted them to be......the inevitable happened.
      De most difficult in the built process is symmetry PS & SB. In this specific case another plane had to be encountered for “Upper & Lower” part of the tailpiece.
      Grtz,
      bart
      One done
      Both done
      Test fitting lower and upper
        • 13997
        #93
        Grtz,
        bart
        One done
        Both done
        Detail FREAK!!
        (have my baby!)
          #94
          Apart of the above tail pieces and Scott's BELUGA....I BUSTED MY ASS PAST WEEK ON THE VICTOR III
          I just finised the upper middel sections and the transsition sections. Yes I try to name every part so I can keep the overview.
          After months of R&D and buiding you can't beat the feeling when you line up all the parts and you actually see the upper part of a submarine apear, It's better then morningwood.
          Both subs are 1/96......I'm so happy with the BELUGA......it must be awesome if they lay beside each other in the water, can't wait to see that.
          Grtz,
          Bart
          Click image for larger version  Name:	P10502261.jpg Views:	1 Size:	174.4 KB ID:	128040
          Click image for larger version  Name:	P10502206.jpg Views:	1 Size:	199.1 KB ID:	128038
          Click image for larger version  Name:	P10502215.jpg Views:	1 Size:	193.2 KB ID:	128037
          Click image for larger version  Name:	P10502243.jpg Views:	1 Size:	289.2 KB ID:	128039
          Click image for larger version  Name:	P10502252.jpg Views:	1 Size:	294.6 KB ID:	128036
            That Victor looks FANTASTIC!!! (Also, it looks like your Beluga has measles. Better not let them get too close.)
              • 3767
              #96
              wow, that looks great! I know a gentleman in Colorado that is itching for your Victor III.
                Looks like the measles are spreading!
                  #98
                  I finished the lower hull master, the new creeper shafts are in and adressed the holes for the rudder which were not centered.
                  Grtz,
                  Bart
                  New creeper shafts
                  Made a tool to drill the new ruddder holes
                  And last but not least the lower hull side by side with the upper.
                    • 13997
                    #99
                    Jaw dropingly good looking work there, Bart. Beautifully designed fixtures and lay-out. Real good stuff, sir.
                    • Peter W
                      • May 2011
                      • 511
                      #100
                      Absolutely 1st class Bart. It looks every inch (25.4mm) a Victor III.
                      Peter
                        #101
                        Thank you guy's, I'll take it........still have nightmares because of the flat deck......the fwd dropdown, the width, the concaveness......I think I changed it a trillion times.
                        Grtz,
                        Bart
                          • 3767
                          #102
                          yowza - that is beautiful!
                            #103
                            Hé Pa learned a new word "yawza", thks Tom.
                            grtz,
                            Bart
                              #104
                              I saw the D&E video a few times now.....I have a question.......how you integrate the index lip into the hull like the picture below?
                              it looks like a gelcoat is also applied in the index lips....can't figure it out.
                              thks, grtz,
                              Bart
                                • 13997
                                #105
                                The indexing lip is homogeneous with the rest of the rubber glove-mold used to give form to the hull half. The hull half master with the lip is formed from three-pieces: The hull half master itself, then attached to it the thin indexing board, and to that the stand-off board. The work goes down on a mold-board and the rubber glove-mold built up over the three-element master, followed by the hard-shell mother-mold.
                                Normal GRP layup is done in the assembled mother-mold and glove-mold tool. And that's it.
                                A heavily filled gel-coat is applied to the tool where the lip will be formed -- this to radius the right-angle faces between hull edge and face of the indexing lip. Once the sharp edges have been radiused smooth I proceed with a normal gel-coat followed by laminates of glass in the normal manner.
