1/96 Romeo - Wherefor art thou?
    • 13943
    #136
    HEY! That sounds promising
    That's the good news. Now, the bad news: he told me who I have to kill .... Mark!
      • 3732
      #137
      whew, dodged that bullet. Sorry Mark it was nice knowing you.
        Well, it makes sense. Kill off the best talent first - that's you, Mark. Mind you, I can be bribed.
        A frustrating day at the cave dealing with other ****. Hopefully I'll get it in the water tomorrow. Meanwhile I have been playing with the safety bouys.
          And the other one that didn't show up for some reason?
            You cant kill me, you don't even know where I live.............................OH Fiddlesticks, I gave him my address!!!!!
              • 13943
              #141
              (cue the Whaa, Whaa, Whaa horns)
                Took the Romeo for a run today. For some reason the Motronics ESC overheated and cooked the bow plne servo - so no diving below periscope depth. Rather strange really. Anyway here it is.
                  • 13943
                  #143
                  Looks like you got it under anyway. You need to further vertically distance the c.g from the c.b. Roll stability is marginal. Neat running boat!
                    Yep. There's not much room in there for anything. I'm seriously considering ditching the SAS setup and just going with gas. It will give me a small amount of extra room at the top of the SD that I can pack with foam and will allow a similar weight of lead to be put into the keel.
                    Strange happening with the ESC however. The boat just stopped; the ballast blew and it heeled over; the bow planes stopped working and then the main drive came back. Weird. When I opened it the ESC was red hot. Not sure what happened.
                      • 13943
                      #145
                      Is that a 2" SD, if so I installed that ESC. Did one of the propulsion motors/shafts lock up? There was a big-time shorting issue with the Mtroniks Marine-10's a few years ago -- for some reason the entire H-bridge would short resulting in a near explosion. Got to know why your ESC overheated. More dope required.
                        There is a lot of debris in the dam at the moment. That said, both of the props are shrouded and should have been kept free of anything that might have jammed either one. The sub behaved very strangely when the bow servo gave up. When I pulled the SD it was warm and when I opened it I couldn't touch the ESC. I'll pull it all down today and replace the ESC and the bow plane servo.
                          • 2035
                          #147
                          Beautiful Pond! I wish I had a something with that clarity nearby.
                          • 598602G
                            • Jan 2017
                            • 518
                            #148
                            Mr Scott maybe it was the warp drive over heating mate
                              Cap'n; I've been shovelling plutonium up this thing's arse all afternoon. I tell ye. She'll no take the pressure!
                                Its actually down about five feet. Its been extremely dry here this summer and I've been sucking water out of it like crazy to keep the orchard alive.
