Got the right temperament to tackle tightening the rudder's grub screw.
I needed to make a tool to reach. I took a length of brass rod and drilled a hole at the end slightly larger than the hex wrench (.050). Soldered a small cut off of the wrench into the end.
Took the hull outside and was able to finally get the rudder tight.
There are numerous ways to put your WTC together. So, here is mine. I placed the Mtroniks under the motor.
Placed some velcro on the tray and some under the RX.
Placing the RX sideways will not work. It is too wide especially when the servos get plugged in. I could mount it under the shelf where it is a wider part of the tube, but still too tight. Could not mount it vertically, the RX was too tall. I could cut a slot out of the tray, but it would interfere with the vent servo.
Fortunately, it looks like placing it this way it will just go over the servo.
The downside is my speed controller's connector is short going forward.
