Something to replace the Neptune - Short Typhoon?
  • TuptubBuilder
    • 146
    I don't want to hijack your thread but pumps are a real sticking point when it comes to this hobby (IMHO). It may be worth discussing at a Dive Tribe Meeting.
      • 2532
      I recall OTW experimented with a vane style air pump in the early days of developing their own dive modules after Brian Cornelius stopped making the Craycraft dive modules, which were largely based on Nick Burge’s modular system. They eventually settled on a Shurflo pump, and latterly they seem to be using gear pumps in some of their modules.
      Pressure wise it depends on the system being used, pressures tend to vary between virtually nothing for an aspirated tank, to perhaps one atmosphere to half fill a sealed tank.
      I’d say a small geared pump using appropriate and good quality materials with easily replaceable parts would be the most useful as it can work on any system, but the elephant in the room is cost, which is likely to be high for a low volume item compared with mass produced items.
      Something that may prove more simple is to get a Kavan pump, and make an adaption kit to take a smaller motor, as the pump head itself is not excessive in size. A small brushless outrunner or even a smaller brushed motor would significantly shrink the footprint.
      • Ed Kirk
        • Dec 2025
        • 75
        I started this project with the idea of using clear tubing to enclose components and design and print my own end caps and seals, it has evolved into a modular system with components either in the water side or in enclosures that I design and print. My modular tanks are looking very promising, I can design any size or shape and print it, redesign and print other components to get desired results. I'm using square "O" ring material to seal the caps on my water tight enclosures similar to the seals used on doors and hatches on real submarines that fit flush. Just looking for a decent pump, my pump module is simply swapped out if I want to use something else. Sort of an after effect of using the Du-Bro fuel tank for ballast.
        My real challenge is sealing the wires. Thinking about a cup setup that I backfill with epoxy resin to seal the wires, currently sizing and fitting my components. Pleased with progress, haven't decided if I am going to use external connectors or running wires directly from servos and motors into electronics compartment with permanent seals. And trying to keep it simple.
        I really like the looks and design of the Typhoon, I just shortened it up to make it into a fun runabout hobby project and something to experiment with. Evolution in progress. The threaded rods in the lower hull sort of evolved, needed a way to mount components in the hull and an after effect is the ability to bolt sections together and exchange sections.
        And 3D printing is insane, I used to make parts with CNC router, mill and lathe. They just collect dust in the garage. No more layup and casting fiberglass either.
          • 3540
          A "What if" a mothballed SSBN was converted to an SSN with removal of the missile tubes.
          • Ed Kirk
            • Dec 2025
            • 75
            Original SSBN was converted from SSN cut in half and missile section added. There was some talk about converting decommissioned SSBN's and SSN's to emergency electrical power plants.
            • Ed Kirk
              • Dec 2025
              • 75
              My pump module in final stage of completion, fits like a glove, just need to pass wires and tubing.
                • 2532
                If you're printing your waterproof boxes, why not print the ballast tank too. Could incorporate it into the hull reducing its length and would also stiffen the hull considerably.
                • Ed Kirk
                  • Dec 2025
                  • 75
                  That was my first goal but I seen the Du-Bro fuel tank and just liked it. I like it is transparent (sort of). It comes in many sizes but like anything these days it has to be ordered. Hobby shops are scarce and don't stock much for the builder.
                    • 3540
                    Uncanny resemblance
Name:	Screenshot_20260216_123125_Adobe Acrobat.jpg
ID:	193701 Click image for larger version
Name:	Screenshot_20260216_122938_Adobe Acrobat.jpg
ID:	193702 Click image for larger version
Name:	Screenshot_20260216_123006_Adobe Acrobat.jpg
                      • 2532
                      That is Colin Gross's model of Deep Quest, although he named it Ross Winan's
                        • 1994
                        Loving this project! I have plans to do the same, but with a Type VII to make it more cartooney. Maybe put a cartoon crew aboard, lights, et all...
                          • 3540
                          [QUOTE=RCSubGuy;n193750]Loving this project! I have plans to do the same, but with a Type VII to make it more cartooney. Maybe put a cartoon crew aboard, lights, et all...
                          [/QUOTE.............
ID:	193752 Click image for larger version
                            • 1994
                            [QUOTE=redboat219;n193751]
                            That's what inspired me! I have one sitting here on my desk.
                            • Ed Kirk
                              • Dec 2025
                              • 75
                              Finishing up stern, rudders and planes. I combined the two parts of the upper and lower rudders so they are now one piece each and attached to a common rudder post. Stern planes lengthened to 150%. Also installed set screws to all planes and rudders. Finally got a radio and sorted things out so I can start connecting moving parts and testing.
                              • Ed Kirk
                                • Dec 2025
                                • 75
                                #30
                                Project moving along, I decided my modular process didn't leave enough space for components. I went back to my original plan to print a tubular design, the center tube is dry for electronics and battery. I plan on using epoxy to seal the tank from the inside. Filled ballast section - 36 oz. water.
                                My SubSafe inspectors at work.
                                I am working the project from the outside - in and acquiring needed components as I go so process is slow. Just got battery and FrySky receiver, able to connect RC and test, so far working great.
                                Edit: The threaded rods are great, allows for easy modifications and changes. I still haven't glued the hull sections together just the bulkhead for the motor mount is glued in place. If the hull was longer the motors could be mounted on the same section as the aft servos.
