Getting closer to finishing the Japanese I-400 Subs AA guns
  • Sinksalot
    • Mar 2020
    • 332
    Well I got the supports off, but one of the gun sights broke off. I going to need to thicken the bar that holds the sights. Everything else seem to have come out fine. I-400 AA gun. I also still want to add a little bit more detail to the rear of the guns.​
    Click image for larger version  Name:	329358216_877306503385443_4018419145659392373_n.jpg Views:	0 Size:	63.6 KB ID:	169296
    Click image for larger version  Name:	329179229_491187359839578_9106123302935705584_n.jpg Views:	0 Size:	64.5 KB ID:	169297
    Click image for larger version  Name:	329405667_733412905116161_8734747919595301411_n.jpg Views:	0 Size:	63.9 KB ID:	169298
    Click image for larger version  Name:	329628071_1457920751404081_3274944409290543237_n.jpg Views:	0 Size:	64.8 KB ID:	169299
  • Scott T
    • May 2009
    • 378
    Since the sights are most likely adjustable or removable you might want to shorten them closer to the horizontal holder. Picture from WEB.
    • Sinksalot
      • Mar 2020
      • 332
      Yea there a lot of versions of the AA gun, land, train,ship, and sub. Sad part one sub had different versions from its sister sub.
      Click image for larger version  Name:	I-400 AA gun back.png Views:	0 Size:	42.7 KB ID:	169323
      • Wizzard033
        • Sep 2023
        • 41
        Very cool. I love printing and these look great. I've printed some similarly difficult models.
        • Alucard
          • Aug 2023
          • 101
          they look good
            • 1797
            I wish I would have hat a resin printer when I built my I-400!
Name:	i-401 deck guns 2.jpg
ID:	173716 Click image for larger version
Name:	i-401 fimished 3.jpg
            All 3D printed with PLA on my 3D40 Dremel.
            "Firemen can stand the heat."
            • Wizzard033
              • Sep 2023
              • 41
              Nice! It looks great.
              I have a model of a type VII C on my Creality cr10s now.
                • 1797
                Wizzard033,
                Your Type VII-C is looking good! Those parts look clean and crip. Are you using PLA? Make sure you keep the photos coming.
                • Wizzard033
                  • Sep 2023
                  • 41
                  Wizzard033,
                  Thanks, yes its PLA first, then I'll probably try ABS, and maybe even break down a model and resin print one also.
                  • neitosub
                    • Nov 2021
                    • 129
                    Can’t help but notice that there’s seems to be some gaps between the hull walls, what infill % are you printing with? You should be printing at 100% infill to avoid water seeping into the air gaps.
                    • Wizzard033
                      • Sep 2023
                      • 41
                      Actually 0% infill. I plan to dissect the hull and fiberglass the interior with 2oz cloth. Also I will open all the scuppers and such from the backside.
