3d Disney nautilus
  • Mrstude
    • Sep 2022
    • 16
    3d Disney nautilus
    Just started my 3D printing adventure. Working on a Nautilus. 66" files reduced 50%. Coming along pretty good. This will be a static display. The steering house and rear section will be held on with magnets to allow access to the lights.
    • 1797
    Mrstude,
    Your printing work looks great! Very nice detail. Good luck on your build. :-))
    • Greeblegremlin
      • Sep 2022
      • 6
      Wow very nice!
      Did you do the 3D modeling?
      • Mrstude
        • Sep 2022
        • 16
        Originally posted by Greeblegremlin
        Wow very nice!
        no I got the files from CGtrader.
        • RockMechanic
          • Sep 2022
          • 2
          I am also looking to start a different Disney submarine build (not the Nautilus), probably going the 3D printer route as well. But I have to ask did you just find/purchase a 3D model to use, or did you create it yourself?
          • Mrstude
            • Sep 2022
            • 16
            Found on CGtrader
            • rkbob
              • Sep 2022
              • 6
              Can you tell me which file you used from CGtrader ,
              Thanks Bob
              • CC Clarke
                • Aug 2020
                • 240
                This is likely it. The creator is a very skilled modeler.
                Nautilus detailed 3D model 3D printable | CGTrader​
                CC
                • Mrstude
                  • Sep 2022
                  • 16
                  .. FYI...
                  The files I used are on CGTrader. They are the 66"-1/36 size. They list for 59.99 but have been on sale for as low as 17.99. I have reduced the size 50%. (33") the part fit is really good.
                  The files have 2 types of Sub, one with rivets and one without, and 2 build styles, full section parts or sectioned parts. There is a PDF file that shows pictures of the parts in each .ZIP file. The file names are in German. So the pdf helps sort out the parts. Hope this helps.
                  • Mrstude
                    • Sep 2022
                    • 16
                    A few more parts added. Motor installed and lights. I used leds that imitate ambient (incandescent) lighting. I think they are more period correct. BTW......If you are going to use " Rustolium Dark Steel as your base color, you might want to buy it now. It is apparently discontinued. very hard to find.. I found some at Target online..
                    • Mrstude
                      • Sep 2022
                      • 16
                      Update: printing small items is quite a challenge. The hatch doors are difficult. The hand wheels are also difficult. If you print them horizontal, they will require supports. Unfortunately, the underside looks horrible, where the supports are. Going to try vertical print to see if things improve.
                      • Mrstude
                        • Sep 2022
                        • 16
ID:	164721Click image for larger version
ID:	164722Click image for larger version
ID:	164723Click image for larger version
ID:	164724Click image for larger version
ID:	164725Click image for larger version
ID:	164726Click image for larger version
ID:	164727Click image for larger version
ID:	164728 Main sub assembled. Fabricated a new stand. Painted and started the weathering. I dusted some Dark Copper over the Dark Steel to tone it down, added a wash and rust on the rivets. Top starboard side almost finished!
                          • 1777
                          Looking great! Good job.
                            • 1160
                            I thought Disney had exclusive rights to the Nautilus. Did they lose their copyright?
                              • 1777
                              Nope.. just too big to worry about a few digital copies of 3D files. It would cost more for one of their lawyers to glance at a screen than they'd get out of a lawsuit or effort to shut anyone down.
