Nothing worse than a physicist stupefied by the obvious
    • 3610
    Quote from Macgyver "Hell Week" episode.
    This popped into my mind after coming across a post on an FB RC sub group.
    The builder has essentially given up, saying it a "disappointment" and "discouraging" because vendors don't stock "oblong shafts" to match his 3D print.
    Click image for larger version  Name:	Screenshot_20260404_091558_Google.jpg Views:	1 Size:	70.3 KB ID:	194377
    a perfect example of a "CAD-induced" crisis. He designed a hole (or used a file) that assumes a specific, non-standard geometry, and now he's treating a simple mechanical interface like it's a proprietary aerospace component.
    This is pretty much a DIY hobby, if the part doesn't exist, you make the part—or better yet, you don't design a hole that requires a unicorn to fill it.
    He did the 90% that requires high-tech hardware and software, then got "stupefied" by the 10% that requires a hammer and a file.
    • 3610
    Off the shelf fix that doesn't require machining or additional work would be to use K&S brass stock.
    Find a square brass rod or tube of the correct width that fits into the oblong 3D-printed hole perfectly. The flat sides of the square provide a massive mechanical lock against the flat internal walls of the print. No slipping, no "oblong" magic required. The gaps on the sides provide space for RTV or epoxy.
      • 13824
      And that's how you segrigate the hacks from the pro's.
        • 2547
        It’s an issue for those who just buy a file and hit go on a printer.
        A bit of basic work with some free software like Fusion 360 and you can have whatever shape and size of orifice he likes in those hydroplanes. Alternatively, a bit of basic benchwork with a file to whittle away at some round stock.
          • 3610
          When something does not include the caption "Download file", "PRINT" or "Add to cart" it doesn't exist.
          • Akula54
            • 43
            Yes, I found it inappropriate for the 3D designer (rcsubs.cz) to complain to the whole world about such a trivial matter.
            I even replied with an obvious solution, which must not have been to his liking since he didn't react at all.
            A file, a brass rod, and the problem was solved...
            On a group frequented by experts and artists in the RC submarine community who all share their work (i.e.solutions), it's pathetic.
              • 2012
              Maybe I'm missing something, but I'd just drill the hole out round.
              Done.
                • 3704
                This thread is what David has complained about for many years about the type of person using a 3d printer, While it is true the answer to us is simple, he is at least building a sub. This gentleman is learning. We all can’t be born with the wisdom to create parts, so this person will either cry in a corner or rise up and start fabricating parts he needs. (Kind of like that scene in 2001 with the apes and monolith)
                  • 3610
                  Just find it strange coming from a guy who claims to have 35 years of RC flying under his belt. Note that he has already finished a giant 3D printed Alfa from Bob.
                    • 2547
                    Ah well, worse things happen at sea.
                    He seems to be have been a helicopter fan- they tend to come with everything in the box. Model subs are a bit more like model helicopters back in the 1970's.
                      • 3610
                      Most probably a catalogue shopper for the 35 years flying RC.
                      Every precision or specialized part needed came from a vendor. His experience is in sourcing and assembly. If he can't source it, he can't assemble it.
                      With exception to the electronics everything else in RC submarine hobby is pretty much a DIY job.
                      • TuptubBuilder
                        • 152
                        Not everyone has an epiphany. My occurred watching the late John Dutton’s You Tube Channel (Scratch built with John). I miss his mentoring.
                          • 2547
                          At present there is a plentiful supply of cylinders, hulls and full kits if you want. However if you are very specific about the subject and scale of the boat you want to make, then chances are you will have to get your hands dirty.
                          For me that's the appeal of the hobby, for others it may be a frustration.
                          • Fishb0y
                            • Jul 2023
                            • 148
                            I appreciate his enthusiasm, but his posts are starting to feel a bit exhausting. I’m a strong supporter of 3D printing as a positive force for the hobby—it helps far more than it hurts. That said, I feel that offering your services to "produce" subs for others, then throwing up his hands in frustration because he cant get a round peg in a square hole is a bit excessive.
                              • 3704
                              Very true. Hopefully he is not selling Bob’s 3D file subs, I thought his licensing is personal use only. Anyway, we can all have an off day, but his did strike me a bit odd. Romel, how is your sub coming along?
