Methods of incorporating neat and accurate "sea steps" in 1/72 & 1/96 scale models?
  • wlambing
    • Nov 2020
    • 359
    Getting an accurate depiction of these common features is problematic, at best!! Could some of you more accomplished modelers share your methodologies here in Tips'N Tricks. We great and unwashed masses would much appreciate that! Thank you!!
    • 13394
    You talk'n about the openings in the sides of the superstructure acting as foot and hand holes?
      • 13394
      • SubICman
        • Jun 2022
        • 87
        Indeed he is Dave. We have had this conversation several times. My filing game is ok, but I can stand to learn some more.
          • 13394
          • SubICman
            • Jun 2022
            • 87
            Nice! That's why your the best Dave.
            I took a slightly different approach on the Kaiyru tho. Theough my research if found that those ateps were acrually closed on the backside. I 3D modeled them and yes I printed them, then did the same as you demonstrated above.
              • 13394
              Penetrations, weld lines, access plates, and even overall geometry of these boats was as varied as the sub-contractors and yards that horridly slapped these things together in anticipation of the eventual amphibious landings that were to befall the Home Islands. Two eggs put all that to rest.
              • wlambing
                • Nov 2020
                • 359
                Yes, the semi-circular holes! The bar type thingies are more correctly known as "grab irons". I see you teasing me with the master hull for the Foxtrot! You *******!!!! Currently working on her sail. That's where I want to replicate those steps. I do use the drill hole, insert half-round plastic rod, glue trim, fill, sand, repeat on the larger scale hulls. The cast resin sail isn't as easy as one would think it to be, due to thickness and the rough inside of the sail half. I'll get 'er though!!!!!! BTW, know where I can get an anchor for her? There was a missing sprue tree and some other stuff not included when this beast was purchased, way back when.
                Thank you, David, just what I was hoping for!
                Take care,
                Bill
                • SubICman
                  • Jun 2022
                  • 87
                  True. That's what makes these nice to model. It's your choice, nothing within reason is wrong
                    • 13394
                    Take care,
                    Bill
                    Tooling on the 1/72 FOXTROT was never completed, Bill. But all masters and what tools I did make are in Bob's hands. What I was working on was my GRP hull, not the master, I assume Bob got them when Mike Caswell turned the business over to him -- but I'm not sure of that. Check with Bob.
                    Here, let me twist that knife a bit more... does it hurt yet?!. https://youtu.be/wJ0Sxr2gvV8
                    • QuarterMaster
                      • Sep 2015
                      • 1213
                      Dave,
                      Show us your "Jacob's Ladder"!!
                      v/r "Sub" Ed
                        • 13394
                        Dave,
                        In my world a Jacob's Ladder is a portable, flexible ladder strung over the side, consisting of rope and wooden steps. Don't remember modeling one of those, Bob.
                        • wlambing
                          • Nov 2020
                          • 359
                          Ed,
                          You were in charge of the ships sewing machine, so get you thread out and knit one! )
                          I don't believe you shanked me! I think it was a healthy pinch with lock-wire pliers, followed by a good yank! At least that's what this Lower-level Louie would do! ;) What, were you trying to corner the world supply of Dremel tools, too?
                          Thank you for those additional pictures! They will augment my other research files nicely!
                          Take care, All!
                          Bill
                            • 13394
                            Ed,
                            Take care, All!
                            Bill
                            Still got my lockwire pliers from the WEBSTER days. Serv-Mart special!
                              • 3378
                              Nice thingamajig.
