microviper 10 esc stutter forward only
    • 12369
    #31
    Yes to all the above. Investigating. Good points.
    • satlite440
      • Jul 2012
      • 177
      #32
      any updates on this problem yet???????as i still have the stutter as well?
      • Slats
        • 1776
        #33
        Your last observation is a good one. I'll swap out the entire device tray to a new motor-bulkhead with fresh motors. If that solves the stutter problem, I'll back-track through the entire motor-bulkhead assembly and find the bad-guy.
        Good thinking, pal!
        I can now put down this three-pound sledge-hammer.
        Not wanting to Hijack this thread - but here we have the very best in customer service in operation.
        ---and people wonder why I praise the Caswell / Merriman RC sub business.
        sigpic
          • 12369
          #34
          Got side-tracked with production work. I'll have it worked out over the weekend. Sorry about the delay.
            • 2848
            #35
            Awww!!! Shucks! We're embarrassed. HWSNBN is shuffling his feet and he's colored up! Me too! BLUSHER
            • satlite440
              • Jul 2012
              • 177
              #36
              thanks david since this is the root problem i am haveing.. i await the diag with baited breath..... so we will see if i need a new microviper10 or a moter.. thanks shane
              • H2Ohaze
                • 117
                #37
                I think David already ruled out the esc. It could certainly be bad motors. Or it could be bad capacitors, but there's not much that can go wrong with them. Or it could be inadequate shielding of some kind...the motor cans are not "tied down" or even the sheet metal that forms the tray that the motor cans more or less touch.
                I worry more about my starboard motor weaker than port, rather than momentary motor stutter forward, as this would mean going about in circles to some extent. :)
                +1 there on customer support.
                  • 2131
                  #38
                  Don't you believe it. Plenty of bad things can and do go wrong with capacitors, and they cause a lot of intermittent and difficult to trace faults. Electrolytics are the worst, ceramics tend to be much more rugged, but they can go short circuit, so don't rule it out.
                    • 12369
                    #39
                    I'm going to swap out the entire motor-bulkhead-motor assembly and if the jitters goes away I'll back-track to the origional motor-bulkhead-motor assembly and check things out there -- one motor at a time -- and find the source in the motors or (as andy suggested) the cap's.
                    • satlite440
                      • Jul 2012
                      • 177
                      #40
                      any updates yet?
                        • 12369
                        #41
                        any updates yet?
                        Been down with flu. Coming back up to speed.
                          • 2848
                          #42
                          Good grief! Get back to work! You don't have time for flu! Very Angry
                          Anyhow, just shows you slacked off and stepped outside The Cave! How else would you have caught it! Never mind, you can work Christmas Day to make up! No turkey for you pal!
                          • satlite440
                            • Jul 2012
                            • 177
                            #43
                            well merry xmas....a BIG RAVE ABOUT DAVID YEA!!!!!!!!!! micro10 just showed up in the mail!!!!!!!your a hell of a guy.. thanks..get well soon huh?
                              • 12369
                              #44
                              Sorry I'm so lat with it ... there's this SOB in NY who's been monopolizing all my time.
                              • satlite440
                                • Jul 2012
                                • 177
                                #45
                                it'sall good. now i just gotta plumb it in....
