Last video from the past, and some more work on the radarmast, also made a start with the radar itself,
Rebuilded the launchtubes for giving me a better trajectory, still needed some tinkering on the hatch on one of the tubes.
The last holder was a bit tricky due to the angles, needed three tries to ge me a symmetrical pair.
Builded the other holders the same way, the width of this piece of wood is the same as the diameter of the mast, the pieces are glued down with CA, so be carefull during soldering, CA fumes are not healty.
All four pieces together on the mast, next step will be clipping them to the right size and glueing them tight.
For building the radar i made a new jigg, the tricky part is, getting the right shape in both directions, i needed also to get a upright angle on the radar itself, by gently bending both rods backwards i managed to get the right angle.
