How do you make decent looking limber/vent holes?
    • 3667
    I have just recently learned what not to do on fiberglass hull, do not use a drill bit that is too big.
    Although I will be able to finish the limber hole with in the scribing lines, there was a lot of separating of the laminated layers. This is my first travel into glassed hulls. All my prior subs have been plastic. What a different game this is! Here I tried three holes with a larger bit. Not happy with what was going on I went for a much smaller hole. I will try my coping saw on this to see if it will cut out the area O.K. If not, I will put in a few more small drill holes inside the limber hole. No matter what I end up doing there will be a need for filing to finish.
    To add to the conversation, what do you do to remove fibers that stick out? Do I use an X-Acto knife and cut the hairs?
      • 13558
      You coat the 'hairs' with CA, which stiffens them, then file away.
        • 1966
        I find that sandpaper from the back side works well to get the majority of them addressed as well...
          • 2461
          Funny place to keep your sandpaper!
            • 13558
            gee, thanks, Andy!
            anyone got a can of Drano? I need to chemically scrub that imagery from my brain ... pronto!
              I had a really good look, but I can't find any sandparer in my backside. Am I missing something? Should I be eating more sand?
              • Ken_NJ
                • Sep 2014
                • 977
                Old school way. Drill and file. Of course not as many on some other boats. Think these took about 2 hours.
                • Ken_NJ
                  • Sep 2014
                  • 977
                  Second set of pics.
                    • 651
                    Whats the difference between Rabbitts and Hares? You cant pull a rabbit out of your Ass
                      You need to go to more magic shows in Thailand!
