USS 581 Blueback
    • Jan 2020
    • 1009
    So remove the strips and screws after the epoxy resin and cloth on inside has cured?
      • 13597
      Yup. Then a thin layer of saturated glass cloth on the outside, some sanding, priming, identification of dings, filling with air-dry putty, sanding, priming, cursing your clumsy hands, paint, touch-up weathering, swearing to God you'll be more attentive next time, clear coat, and you're good to go.
      Idiot!
      The Horrible
        • Jan 2020
        • 1009
        Is glass cloth fiberglass cloth? Will this pictured below be correct? What 2 part epoxy resin do you guys recommend?
          • 13597
          That will work, but is a tad heavy for this job. Cut it into 1/2" squares to make lay-down an easy matter. Ideally you would use 2-4 ounce cloth (per square yard). Best laminating resin is West System.
ID:	143423Click image for larger version
ID:	143424Click image for larger version
ID:	143425Click image for larger version
ID:	143426Click image for larger version
            • Jan 2020
            • 1009
            Thanks David
              • 1936
              Bruce,
              I have used ZAP Z-POXY two part finishing resin with light weight glass on a couple of my Byron War Bird airplane wings (in the day) and it worked very well. I have also used it on two of my 3D printed Submarines along with fiber glass to enhance the strength of the glued up sections of the hull! I am sure there are many finishing resins out there that will do the job!
                • Jan 2020
                • 1009
                Thanks Rob, I tinkered with rc planes as well, then did helis for a long time, mostly scale helis. Now I fly drones, so much easier! Did get my Drone Commercial Certification as well.
                  • Jan 2020
                  • 1009
                    • Jan 2020
                    • 1009
                    The Safety Float Valve Battery Chamber Manifold broke off, I am using the Snort System so how should I reattach manifold, or should I just seal the hole, either way should I use epoxy? I had allready plugged the tube from the safety float valve to the manifold with a rod.
                      • 13597
                      You've already trimmed the boat, so leave the unused safety float-valve in place and blank off the nipples.
                      Blank off the hole where the manifold broke off (CA and baking soda).
                      Blank off the internal nipple of the 4-point manifold where the safety float-valve made up to it. Run the hose from the snorkel straight into the suction side of the motor bulkhead. Now you're in Snort mode. Done.
                        • Jan 2020
                        • 1009
                        Thanks My Lord!
                          • 13597
                          Thanks My Lord!
                          That's right... my head's not fat enough yet.
                            • Jan 2020
                            • 1009
                            Bahahahahah!
                              • Jan 2020
                              • 1009
                              Guys, just an update, the tail attachment was successful, thanks for the help! Btw, the West Marine epoxy was excellent!
                                • Jan 2020
                                • 1009
                                #30
                                I will adjust the lean to port
