USS 581 Blueback
    • Jan 2020
    • 1036
    USS 581 Blueback
    Video of first sumerged diagonal manuevers link
    • Jan 2020
    • 1036
    USS 581 9/6/20
      • 13982
      What's the story on that leak?
        • Jan 2020
        • 1036
          • 13982
          What happened???? You need parts -- just post me what you need and we'll get you back in the saddle, Cowboy.
          dmeriman@aol.com
            • Jan 2020
            • 1036
            David, I was transferring it to my “Travel Stand” preparing to go home tomorrow, sat it on my bar at pool..... gust of ocean wind blew it off the bar.... 5’ to pavement....... I will let you know, thanks David. Good news is that the teflon tape seemed to work, will better check for Cylinder crack across the O Ring when get to home base. I think the Cylinder is not damaged, it landed on the prop, as it no longer has a point, lol. Will have to figure out how to reattach the tail. All in all, could have been worse.
              • Jan 2020
              • 1036
                • 3756
                Ouch, sorry that happened.
                    • 1647
                    This happens to us all, as for fixing this, take some small copper strips to get the broken part in line to the hull, fixade the strips with some machinescrews, take some glasscloth and epoxy resin to reinforce it from within.
                    Repare the crack and holes from the machinescrews at the outside with 2K bondo, recribe the lines and you are back in business.
                    Inspect your SD from all sides, lexan doesn't like hard hits, use a one light source like a flashlight, this will reveill if there are cracks near the ends.
                      • Jan 2020
                      • 1036
                      Guys, thanks for the encouragement, and Manfred thats the guidance I need too, thanks!
                        • Jan 2020
                        • 1036
                        Manfred, machine screws or self tapping screws?
                          • 1647
                          Glad i could help, it's pretty much the same way as David does, maybe he can enlighten you with some pics for more guidance.
                            • 13982
                            Like this:
                              • Jan 2020
                              • 1036
                              Awesome! Thanks!
