Bruce,
I have used ZAP Z-POXY two part finishing resin with light weight glass on a couple of my Byron War Bird airplane wings (in the day) and it worked very well. I have also used it on two of my 3D printed Submarines along with fiber glass to enhance the strength of the glued up sections of the hull! I am sure there are many finishing resins out there that will do the job!
USS 581 Blueback
DavidLeave a comment:
Is glass cloth fiberglass cloth? Will this pictured below be correct? What 2 part epoxy resin do you guys recommend?1 PhotoLeave a comment:
Idiot!
The HorribleLeave a comment:
So remove the strips and screws after the epoxy resin and cloth on inside has cured?Leave a comment:
Glad i could help, it's pretty much the same way as David does, maybe he can enlighten you with some pics for more guidance.
Manfred.Leave a comment:
Guys, thanks for the encouragement, and Manfred thats the guidance I need too, thanks!Leave a comment:
This happens to us all, as for fixing this, take some small copper strips to get the broken part in line to the hull, fixade the strips with some machinescrews, take some glasscloth and epoxy resin to reinforce it from within.
Repare the crack and holes from the machinescrews at the outside with 2K bondo, recribe the lines and you are back in business.
Inspect your SD from all sides, lexan doesn't like hard hits, use a one light source like a flashlight, this will reveill if there are cracks near the ends.
