1/72 Revell Of Germany Type-9 .... It Starts!
    • 13981
    #61
    Hey, Von.
    If you have plated magnets, I'm game. Our current source is Gauss Boys, http://www.gaussboys.com
    Great variety of product and sterling service. Finished installing the latching magnets for the deck, after I take my hideous nap I'll do the same for the sail.
    As far as electronic interference, there is none providing there is no relative motion between magnets and electronic devices -- no motion, no induced EMF. (Thank you, BE&E school!).
    • Scott T
      • May 2009
      • 414
      #62
      What if you mounted the magnets horizontal from the position you chose?
      Then when the magnets slide into the hull attached magnet holders there is also a
      mechanical hold down as the deck magnets slide partially into the hull magnet
      holders. Also they won't extend as deep into the hull maybe.
      Scott T
        • 13981
        #63
        Working out the master of the rudder operating mechanism.
ID:	85212Click image for larger version
ID:	85213Click image for larger version
ID:	85214Click image for larger version
ID:	85215Click image for larger version
ID:	85216Click image for larger version
ID:	85217Click image for larger version
ID:	85218Click image for larger version
ID:	85219Click image for larger version
ID:	85220Click image for larger version
ID:	85221Click image for larger version
ID:	85222Click image for larger version
ID:	85223Click image for larger version
ID:	85224Click image for larger version
ID:	85225Click image for larger version
ID:	85226Click image for larger version
ID:	85227Click image for larger version
ID:	85228Click image for larger version
          • 13981
          #64
            Hey, Von.
            roger on the plated, I'll send a few different sizes shapes you can experiment with. We get them from a couple different places, overseas at volume. Compaired toGause boys prices there about half. I have an annual order going out this week for ten thousand in various sizes but I have some over ordered that are in the warehouse we didnt use for production, your welcome to have. Quite a few 10mm x 01 discs and some 25mm x 5 x2 mm thick and 20x5x2s. Phase II of BE&E was a blurr for me. It was Oct 62 at the FSS with a sonar class. A couple of us had to audit the class untill they passed on thru the green doors to sonar phases. The weekend we got out of the school on friday and got the 72 hr libbs, and be back aboard at Oh6 monday. Longest liberty I ever would have had up to that time. Sat AM, we went to Miami in whites (no civi clothes back then for PO2 &below) Sat noon we were picked up by the SP on the beach and told that Kennedy had canceled all leave and liberty and get back to the base. Snail addy?
              • 13981
              #66
              worked up the forward and after nest foundations today. F it ... I'm off to bed!
ID:	89133Click image for larger version
ID:	89134Click image for larger version
ID:	89135Click image for larger version
ID:	89136Click image for larger version
ID:	89137Click image for larger version
ID:	89138Click image for larger version
ID:	89139Click image for larger version
ID:	89140Click image for larger version
ID:	89141Click image for larger version
ID:	89142Click image for larger version
ID:	89143Click image for larger version
ID:	89144Click image for larger version
ID:	89145Click image for larger version
ID:	89146Click image for larger version
ID:	89147Click image for larger version
ID:	89148Click image for larger version
ID:	89149Click image for larger version
ID:	89150Click image for larger version
ID:	89151Click image for larger version
ID:	89152Click image for larger version
ID:	89153Click image for larger version
ID:	89154Click image for larger version
ID:	89155Click image for larger version
ID:	89156Click image for larger version
ID:	89157Click image for larger version
ID:	89158Click image for larger version
ID:	89159Click image for larger version
                • 13981
                #67
                  • 651
                  #68
                  All the drain and vent holes in the hull, did you cut those out, or is it moulded like that?
                  • Buellman1
                    • 93
                    #69
                    Basically none of the drain and vent holes are open. The pieces are molded very thin in those spots if you want to cut them open.
                      • 651
                      #70
                      OK same as the type 7 then, someones been busy
                      • reddevil
                        • Jun 2009
                        • 346
                        #71
                        Let's ask the big question: Any estimation about the total cost incluiding subdriver, fittings and weaponry?
                          • 13981
                          #72
                          2000 bucks?
                            Merry Christmas everybody!
                              2000 bucks?
                              Just ignore him folks!
                                • 13981
                                #75
                                With Revell of Germany's permission I'm employing the kit control surfaces and propellers as fittings kit production masters. Prop's had to be cleaned up and fattened up a bit at the blade roots. The stern plane and bow plane leading and trailing edges also had to be thickened up.
ID:	89172Click image for larger version
ID:	89173Click image for larger version
ID:	89174Click image for larger version
ID:	89175Click image for larger version
ID:	89176Click image for larger version
ID:	89177Click image for larger version
ID:	89178Click image for larger version
ID:	89179Click image for larger version
ID:	89180Click image for larger version
ID:	89181Click image for larger version
ID:	89182Click image for larger version
