1/72 Revell Of Germany Type-9 .... It Starts!
  • Slats
    • 1776
    Originally posted by Kazzer
    Look here Mr. M
    I am not your mother. You obviously have a problem with your computer as it keeps posting your messages twice. I shouldn't have to clean up after you, so delete your duplications please.
    And try and find out why your beat up POS of a computer is doing this. Have you rewound the elastic band? Did the duct tape fall off?
    And BTW dare I mention S L A T S order?
    Ha! Ha! Ha!
    David try resetting your internet browser, delete all cookies, delete the cache, and try and see if the double posts don't keep on occurring.
    In David's defense Mike, every time I post I get an error message at the top of the screen. It still posts my post, but its weird.
    Mike - yes do mention my order... as a baseball bat to his knees might cause offence.
    sigpic
      • 13629
      Worked out a rough estimate of how much ballast water the SD's ballast tank will need to hold to get the above-waterline portions of this model below the surface. Little math was required: as polystyrene has about the same specific gravity (density) as fresh water, it was a simple matter of taking all the kit parts of items above the waterline (deck, sail, guns, deck fittings, railing, etc) and weigh them. I then estimated the volume of the sides of the hull above waterline and assigned a weight to that. Added it all together and I find that I need a bit less than 10-ounces of water to get this sucker to submerged trim.
      The 1/72 GATO needs a bit over 25-ounces of water to submerge!
      Great! I can use a 2" SD which will be an un-crowded fit within the hull.
        • 3468
        Maybe you can use a Seaview subdriver.
          • 13629
          You read my mind. Only difference between the 2" SEAVIEW SD and the one for the 1/72 Type-9 is shaping up to be a ballast tank shorter by 4.5-inches and the two motors wired to counter-rotate.
          ... and there's room in there for a forward and after nest. Whooya!
            • 3468
            Wouldn't the Type VII's SD work here? Maybe move the forward ballast bulkhead forward to the battery compartment.
              • 13629
              Then .... where do you put the battery?
                • 3468
                I didn't say put the ballast tank bulkhead all the way forward, maybe just enough to fit in a small battery pack. With a SAS you can drop the internal propel tank giving additional volume.
                BTW, didn't your old wtc lack a dedicated battery compartment.
                  • 3468
                  Edited.
                  Now I'm double posting like him...
                    • 651
                    The type 7 sub driver already has quite a small battery area. And I don't think you will get anything longer than the current type 7 sub driver in the type 7. It's a very tight fit in there, so no the 9 won't go in the 7
                    Back to the IX
                      • 13629
                      They were freebee review, sizing mules sent straight from Revell of Germany.
                        Since Dave said that they modeled it after U505, I started searching thru everything I could find on the U505 Sonar Dome. I came up with these plus a few others.
ID:	84963Click image for larger version
ID:	84964Click image for larger version
ID:	84965Click image for larger version
ID:	84966Click image for larger version
ID:	84967Click image for larger version
ID:	84968Click image for larger version
ID:	84969Click image for larger version
ID:	84970Click image for larger version
                          • 13629
                          I love those shots, Mark. Keep them coming please. And I so appreciate that the museum configured the boat with closed and opened shutter-doors/muzzle doors. What a wealth of prototype information here.
                            • 13629
ID:	84972Click image for larger version
ID:	84973Click image for larger version
ID:	84974Click image for larger version
ID:	84975Click image for larger version
ID:	84976Click image for larger version
ID:	84977Click image for larger version
ID:	84978Click image for larger version
ID:	84979Click image for larger version
ID:	84980Click image for larger version
                            • Scott T
                              • May 2009
                              • 401
                              I know this will make you mad!
                              You can do better on the shaft alignment. Go the extra Mile. You have the ability, I do not.
                              Scott T
                                • 13629
                                #30
                                Scott T
                                Not at all. Critical examination and constructive comment is always welcome. And your statement is fact.
                                However, I don't have the luxury of time. The arrangement I've established remains as is as it has to serve several shafting arrangement, not just the Type-9's.
