A day in The Cave
    #91
    Yes, they will become Limited Edition Collectors items to be sold and sold and resold on Ebay at steadily increasing prices. Except I wont part with mine.
    Cynicism, no matter how accurate, won't get you the boat in the time that you'd like Mark.
      • 13984
      #92
      I hate production work ...
      ... But, the money is very good.
ID:	92029Click image for larger version
ID:	92030Click image for larger version
ID:	92031Click image for larger version
ID:	92032Click image for larger version
ID:	92033Click image for larger version
ID:	92034Click image for larger version
        • 13984
        #93
ID:	92036Click image for larger version
ID:	92037Click image for larger version
ID:	92038Click image for larger version
ID:	92039Click image for larger version
ID:	92040Click image for larger version
ID:	92041Click image for larger version
ID:	92042Click image for larger version
ID:	92043Click image for larger version
ID:	92044Click image for larger version
ID:	92045Click image for larger version
          So whats the Paashe' bottle for? Do you test each and every torp and tube?
            • 13984
            #95
            Yes, I qualify the weapons and launcher -- full up, practical in-water tests.
            Test protocol for the 1/72 weapon system (comprising one launcher and three weapons)
            1. Install a weapon, put launcher to 'battery', charge weapon, and place assembly in water and check for leaks
            2. Take launcher in hand, cup left hand over muzzle and launch weapon, catch weapon and place in water and observe proper run
            3. Repeat for the remaining two weapons
            4. Dry weapons and launcher, bag up and send to Caswell
              #96
              I use a Golden Retriever to get mine from the local lake. Lord Tweedmouth created an excellent gun dog with an extraordinary soft mouth. No scratches on the fish, and the drool I can double duty on the reload as greasing the shot. He doesn't answer back, does exactly what he's told, and is happy to be paid with the thoughts of potential liver treat.
                • 13984
                #97
                Working to finish my SubTech 1/60 ALBACORE kit.
ID:	92241Click image for larger version
ID:	92242Click image for larger version
ID:	92243Click image for larger version
ID:	92244Click image for larger version
ID:	92245Click image for larger version
ID:	92246Click image for larger version
ID:	92247Click image for larger version
ID:	92248Click image for larger version
ID:	92249Click image for larger version
ID:	92250Click image for larger version
ID:	92251Click image for larger version
ID:	92252Click image for larger version
                I hate painting!!!!!!
                  • 3758
                  #98
                  Oh yeah, I can tell you hate painting, look at that sloppy work! That Albacore is looking great. Once you have the dots removed did you do a thinned spray of gray to blend it?
                    Originally posted by MFR1964
                    Or wearing Crocks and smoking weed, that M1 looks more like a foamy to me, newer knew you can stuff that much foam inside.
                    Crocs are the new Berkinstocks and sick people are allowed to smoke the hemp now days. Hell I was makin tie dye shirts in the Navy in 1962 outa my dungerese in the washer when I mistakenly knocked the box of bleach bleach in the machine.
                      • 13984
                      #100
                      Yeah, that's what I did. I first laid down a dusting of the lighter gray over the sonar window portions of the sail, let it dry, then popped off the little masking discs. Then I sprayed on a bit more paint -- just to tone-down the contrast between the dots and the surroundings.
                        • 13984
                        #101
                        Laid down the 'scum' line and further defined the discoloration you see at the rudder and hulls waterline. Grunt work. Ugh! And I started in on the masking required to achieve the 'oil-canning' effect seen on the sail and control surfaces exposed to wave action.
ID:	92273 I wanted to try out a white charcoal pencil for the light colored band at the waterline -- denoting dried and bleached, 'sea grass' that clings and grows on the hull and other surfaces near the surface. In the past I've used oil pencils which are fine if you are faced with a smooth surface, but this model had a rather rough surface, to better hold the charcoal dust once rubbed onto the work. But, before committing to the ALBACORE, I first tested it out on the old, unfinished, 1/96 WEBSTER hull that has been collecting dust for decades.
ID:	92277 Click image for larger version
ID:	92278 The grease crayon would represent 'sea grass' and would be applied and streaked over the white charcoal -- the methodology worked out on the test article, recorded, then applied to the ALBACORE. The green little specks of grease crayon were easily pulled into streaks with the aid of a cotton ball.
ID:	92274 Click image for larger version
ID:	92275 Click image for larger version
                        The initial lay-down of charcoal -- in order to produce a well defined line at the waterline -- was done with the aid of flexible straight-edges cut from .020" polystyrene sheet. The strips of styrene were easily bend and held in place against the hull and upper rudder with masking tape.
ID:	92279 Click image for larger version
ID:	92280 To breath some life into the display I decided to take the time to work in an 'oil canning' effect to the sides of the hull -- the apparent dishing in of the sails plating as a consequence of wave action.
                        When the plating goes concave between stringers and frames it is evidenced by the shade pattern as sunlight bounces off the portions of plate in line-of-sight to the sun. Today I got as far as starting in on the masking for the forward, tightly spaced, dished sections. I'll have it all done by tomorrow afternoon.
                        I dressed up the 1/60 drawing of the sail to indicate the plating observed on the ALBACORE as it sits in its pit today. From that study I determined the dishing pattern, which would be applied, as masking, with tape to the sail itself.
                          I always wondered how you got such a crisp line of delineation at the scum line. Very instructive. I dropped your receiver in the mail today - should arrive in about a week.
                            you cant say thats not Art. I would say fine art at that. I was wondering why you chose to represent her in the way she sits in that mud hole up in November Lima { that stands for "No Liberty", not New London} I think most of the white stuff that streekes her sides now is from the acid rain water run off and the seagull and pellican poop. She looked prity spiffey at the Commissioning in 53 and in the early 50s 'Wheeties box "cammo pic. I really like that grid attachment to the drawing table with the multiple leads. That looks like a "must have one" item on Santas list Click image for larger version
ID:	92281 Click image for larger version
ID:	92282 Click image for larger version
                              • 13984
                              #104
                              Send me your address and want list, please.
                              Dmeriman@aol.com
                                • 13984
                                #105
ID:	92285Click image for larger version
ID:	92286Click image for larger version
ID:	92287Click image for larger version
ID:	92288Click image for larger version
ID:	92289Click image for larger version
