Yep - it’s a big rabbit hole!
  • Timothy L
    • Sep 2024
    • 205
    You know you’re way down the rabbit hole when the hardware store says your 6’ stock tank just came in!
  • Marylandradiosailor
    • Nov 2021
    • 72
    Stock tanks work great, explaining why to the wife I needed this in the basement more interesting.
    • Timothy L
      • Sep 2024
      • 205
      It gets worse - need to change some plumbing in the basement for filling and drainage. But fully supported by my spouse :-) !!!
        • 13890
        Well!! She passed the final test, Tim. Yup... she's a keeper.
        • Timothy L
          • Sep 2024
          • 205
          Step 1 completed: 6’ x 2’ x 2’ testing tank. The bobsled ride down the basement stairs was a thrill. I am very excited about having this essential tool!
          Step 2 build a 2x4 frame and raise it up 24”
          Step 3 have the plumber add a faucet and drain (not ad bad as it sounds LOL).
          Hmmm…..maybe a requirement for RC subs is you must be slightly demented LOL - I’m having fun!
            • Oct 2017
            • 1032
            What sort of tank is that,Timothy? I know the metal tubs( expensive in Germany) but this one is plastic,right?
            Jörg
            • Timothy L
              • Sep 2024
              • 205
              Hi Jörg -
              It is an extremely durable poly(ethylene) tank. Lighter weight and no rust issues - cost $219. The product is:
              Behlen Country 2 ft. x 2 ft. x 6 ft. Poly Stock Tank, 52112027GT
              I’m pleased with it. I was able to get it locally - shipping tanks will double the price.
              Tim
                • 13890
                Hi Jörg -
                Tim
                Enough 'infrastructure' yick-yack!!!!... back to work. Slacker!
                  • 3641
                  Is there a general rule to follow regarding how big your test tanks needs to be? Obviously depends on the size of your model but how much allowance around and how deep?
                  • Timothy L
                    • Sep 2024
                    • 205
                    Speaking only for myself, I chose the 6’ x 2’ x 2’ size because my preferred scale is 1/72. This tank offers all the room needed to test any 1/72 sub I plan to build. My South Dakota (wip) is 61” and the USS Nautilus 571 coming next is 54”. Plenty of room fore and aft, port and starboard. Other modeler’s needs might be quite different.
                      • Nov 2021
                      • 72
                      I'm sure it's totally dependent upon the size of models you build but the 6' also works good for me like the photo above. I like the straight sides of the aluminum tanks like in the link below and they are normally in stock at TS. The other good thing at TS as they often have discount coupons and sales, I got mine last year on sale for $180.
                      CountyLine 170 gal. Oval Galvanized Stock Tank, 2 ft. X 6 ft. X 2 ft., WT226CL at Tractor Supply Co
                      • wlambing
                        • Nov 2020
                        • 389
                        It's a heavy rabbit hole, too! My standard galvanized steel tank (2x2x6) holds 189 US gallons of water. That's 1,512 lbs!!
                        • Scott T
                          • May 2009
                          • 410
                          [ATTACH=JSON]n193738[/ATTACH]
                          test tank!
                          • Timothy L
                            • Sep 2024
                            • 205
                            This one is for DM, LOL - last of the infrastructure photos. So jazzed about having a test tank - just waiting for the plumber (a long wait when you live in the boonies). Now back to the newbie learning curve :-)
                              • 3641
                              Add some caster wheels with brakes.
