HMS X-Class Stickleback Midget Submarine
    • 1937
    I am starting a new 3D printed submarine build.
    Click image for larger version  Name:	HMS STICKLEBACK 6.jpg Views:	0 Size:	27.3 KB ID:	177151
    This will be a 1:24 plus scale RC submarine. I will be using my Dremel 3D40 printer with white PLA filament.
    The above is some more information on the full scale sub and its history.
    "Firemen can stand the heat."
    • 1937
    Here are a few more photos of the HMS Stickleback.
Name:	HMS Stickleback 4.jpg
ID:	177158 Click image for larger version
Name:	HMS Stickleback.jpg
ID:	177160 Click image for larger version
    My plane with this boat is to take it all the way to full diving capability (WTC/SD) and also do some weather on the final finish. The other good thing about this boat if I getit operational is, it will be a great boat for the pool. Every other boat I have built except for the 1:77 scale Nautilus were just to big for the pool.
    "Fire3men can stand the heat."
      • 3502
      https://www.foodnetwork.com/how-to/p...n-on-the-stove
        • 1937
        Romel,
        How did you know that I really like to have a bowl of popcorn on my work bench while I am building. Great site with some good recipes.
          • Jan 2020
          • 1025
          Rob, nice addition. I also drive my subs in my pool, I I often print the rudders larger or add a rudder extender to increase the turning ability. Happy to share my STL files so you can see what I design.
          Bruce
ID:	177169 Click image for larger version
ID:	177171 Click image for larger version
Name:	Image 12-31-23 at 6.04 PM.jpg
            • 1937
            Thank you for the files. I have used these type extenders on some of my boats. The majority of my boats are over 36" long, and in my pool even with the extender, all I can say is I am glad I have reverse. I see you use Autodesk Tinkercad. It's very simple to use and you do get great results.
            Thanks Bruce.
              • Jan 2020
              • 1025
              So around 673MM in length, what size cylinder are you employing? Where did you purchase the files?
                • 1937
                Hi Bruce,
                I got the files from CGTraders. STL files at 1:24 scale at 100% size. I increased the size to 110% and that is the max that I can go with my Dremel. With that in mind I will be going with a 2" cylinder. That means I will have to pull off a David M. cylinder build. Going to be interesting! But, I will make it work!
                  • Jan 2020
                  • 1025
                  Hi Bruce,
                  Yes you will!
                    • 1937
                    I have started to print the main hull for the Stickleback!
Name:	HMS STICKLEBACK 7.jpg
Name:	HMS STICKLEBACK 8.jpg
                    The above two photos show the first two bottom bow sections.
                      • 1937
                      Making more progress on the Stickleback.
                      The photos show additional lower hull sections, and also the 2" cylinder that I will be using for the WTC.
                        • 1937
                        I have been going through some of the accumulated parts from previous builds.
                        Click image for larger version  Name:	STICKLEBACK 6.jpg Views:	0 Size:	54.2 KB ID:	177264
                        These are just a few of what I have that I could use on the Stickleback. At this point I am not sure if I will incorporate a simple low pressure ballast system for this boat, or go with just a partial submersible surface runner!? It's just going to be a fun boat for the pool! I have a lot of David M. photos and ideas as to how to install all this into a 2" cylinder.
                        Time will tell...
                          • 3502
                            • 1937
                            Thanks Romel!
                            That video gives me an idea where I need to be as far as how it is set up for water operation underway.
                              • 1937
                              Romel,
                              Well after watching the great video you put up, what to my surprise was a YouTube video that came next.
                              1:12 Scale British X Craft RC Submarine (youtube.com)
                              It was a video that Bob Martin put up about 5 plus years ago of the X-Class submarine that he had. His video will be extremely helpful as I start the build up of my Stickleback.
                              So! Thank you again for providing me with all this great information. And thanks to Bob for doing the video on his X-Class.
