Guess the boat type....
  • DrSchmidt
    • Apr 2014
    • 1320
    #106
    After applying the rivets I started painting the outer hull. First the deck. It got a dark wood colored primer, topped with Vallejo concrete to create this worn teak look. Continued by shading various boards with highly thinned down sand and grey tones. Grey filter, grey wash to bring out the recesses between the boards and then a finish with dry brushing white grey. Worked out well. After that, I coated the deck with silk clear coat, masked the deck and applied the base color of the conning tower and upper deck structure.
    • DrSchmidt
      • Apr 2014
      • 1320
      #107
      Base colors are applied. With cut-away boats that’s allways a tricky job, as there is no room for error masking the interior. But it went down quite well. Decals are also on. Next is psinting the details and then the weathering.
