Guess the boat type....
    • 1393
    #106
    After applying the rivets I started painting the outer hull. First the deck. It got a dark wood colored primer, topped with Vallejo concrete to create this worn teak look. Continued by shading various boards with highly thinned down sand and grey tones. Grey filter, grey wash to bring out the recesses between the boards and then a finish with dry brushing white grey. Worked out well. After that, I coated the deck with silk clear coat, masked the deck and applied the base color of the conning tower and upper deck structure.
      • 1393
      #107
      Base colors are applied. With cut-away boats that’s allways a tricky job, as there is no room for error masking the interior. But it went down quite well. Decals are also on. Next is psinting the details and then the weathering.
        • 1393
        #108
        Working on the railing of my 1/72 scale Type II submarine Vesikko with interior. As the railing provided with the kit is way too clumsy, I copied an approach I saw in a YouTube video (https://youtu.be/hdhhQDrhcuY?si=m6dl7-52cWE2E7rx) and fabricated my own version out of 0.4 mm outer diameter brass tube. I bent the struts along 3D-printed templates and soldered the vertical rails on the boat. Tedious, but worth the effort.
          • 1393
          #109
          I hate rigging….I cannot imagine how some folks can enjoy rigging historical sailing ships . But it has to be done anyways. For Vesikko the rigging basically is installing the wire antennas with their insulators. The insulators of the kit are cast in resin and are way too clumsy. So I printed new ones with 80% of the kit‘s size. 24 of them. They all got a two tone paint job…tedious. And now it’s me, the rigging thread and superglue. I printed a tool to get the distance between the insulators the same for all 24 pieces. First try worked O.K.. Seven more to go.
            • 1099
            #110
            Good job! The next ones will be done much quicker!
            there's nothing better than a good jig...
            did you print the holes along with the insulatots or did you have to drill them?
            Jörg
              • 1393
              #111
              The holes (0,5 mm diameter) are printed, but don't show up completely. So I had to drill them, but with the pr-printed holes that was quick & easy.
                • 1393
                #112
                Well, all the rigging went into the bin. The thread I've been using is wax coated. I was wondering the whole time, why it was so hard to glue these things together. We'll I found out after I had most of the way behind me. Not for punishment, just for practice. So I'll print insulators and blocks again, and then start over again, this time with proper, unwaxed thread.
                  • 1099
                  #113
                  OH NO! Straight learning curve...
                  nevertheless, i always recommend silk, waxed with flourine
                    • 1393
                    #114
                    Looks boring for the ammount of work that went into it…These are the insulators and blocks for the wire antenna of the 1/72 scale Type II submarine „Vesikko“. The insulators and blocks are 3D-printed, drilled open, painted and then tied together using 0,2 mm diameter high quality polyester nitting thread. Did it twice, as the first time I used waxed thread…wax doesn’t work with superglue. Well that’s a surprise.
                      • 1393
                      #115
                      Mission accomplished. I finished the 1/72 scale Type II submarine Vesikko with interior. 3 years designing and building. I‘m happy with it.
                      Click image for larger version  Name:	Vesikko-181.jpg Views:	16 Size:	55.3 KB ID:	194128
                      Click image for larger version  Name:	Vesikko-182.jpg Views:	16 Size:	61.7 KB ID:	194129
                      Click image for larger version  Name:	Vesikko-183.jpg Views:	16 Size:	58.9 KB ID:	194130
                      Click image for larger version  Name:	Vesikko-184.jpg Views:	16 Size:	60.4 KB ID:	194131
                      Click image for larger version  Name:	Vesikko-185.jpg Views:	16 Size:	62.2 KB ID:	194132
                      Click image for larger version  Name:	Vesikko-186.jpg Views:	16 Size:	61.0 KB ID:	194133
                      Click image for larger version  Name:	Vesikko-187.jpg Views:	16 Size:	65.3 KB ID:	194134
                        • 1393
                        #116
                        And a walk-through video:
                          • 1393
                          #117
                          Could someone please approve the next-to last post?
                            • 1099
                            #118
                            To me, the number of valid pictures is 3, sometimes 4 without needing confirmation. Mybe if you'd split your last post, it might work
                            Another uber-impressive model,Doctor!
                              • 1393
                              #119
                              Thanks....and: I cannot edit the not-approved post.
