The true(?) cost of CO2.
Well, all may not be rosy, or cheaper, in CO2 land....
I wanted to do a cost analysis just to see if it was actually more cost effective than Propel or Freon.
Kinda difficult since CO2, Propel and Freon not only have different properties, but aren't really "standard" with regards to units of purchase.
So I tried too nail to down to "Cost per Gram", then that converted to g/CC and expansion ratio vs how many grams actually used to fill up a 1 Liter volume, then calculate that cost.
I was surprised to find CO2 was the most expensive overall.
Feel free to check the methodology and math. The purchases were through Amazon (your source may be less expensive), cost is in USD.
Source CO2 (10 Cartridges)
Cost/Unit (Amazon) $16.99
Total Grams 160
Cost per Gram $0.11
Density g/CC 1.25
Cost/CC $0.13
Expansion Ratio 535
g/1l Ballast Tank 1.869
Cost per Blow $0.25
# of blows per unit sold 85.6
Source Propel (1 Can)
Cost/Unit (Amazon) $29.70
Total Grams 368
Cost per Gram $0.08
Density g/CC 0.91
Cost/CC $0.07
Expansion Ratio 306
g/1l Ballast Tank 3.2680
Cost per Blow $0.24
# of blows per unit sold 112.608
Source Freon (3 Cans)
Cost/Unit (Amazon) $43.58
Total Grams 1020
Cost per Gram $0.04
Density g/CC 1.24
Cost/CC $0.05
Expansion Ratio 274
g/1l Ballast Tank 3.649
Cost per Blow $0.19
# of blows per unit sold 279.48
Of course this is just a comparative cost analysis of the gas. Actual usage may differ. Your needs may differ. Prices may shift around in the future.
For example, my choice has been Freon for the past 4 years. I buy it by the case. 3-4 years ago a 12 pack of 12oz cans went for ~$65, when I last checked it had doubled. I thinks that's 'cuz I told all you swabs to switch due to the cost of Propel and y'all made a run on it. Or it could just be inflation lol.
I run at least every other weekend. I primarily use my Snorkel Induction to surface the boat, with gas a a backup or used to impress folks. 3-4 cans a year? Gas is often lost through charging. Either through seal leakage as its done, or definitely to get the tanked chilled to accept the gas. Fill, vent, fill again.
Co2 cartridges, being already filled WILL alleviate that. Plus I can set the discharge pressure to limit loss by not forcing everything out at once. IOW metering the output as opposed to dumping it at full tank pressure out the Schrader valve.
The only way to truly know is to test it.
Over the next week I plan to install this (photo) in the usual test platform of mine, my 1:48 Scale RC Submarine USS SHARK SSN-591. I see I need to make some mod's as the goal is to have it in the "wet".
Again, in the long run it may be as expensive as Propel, but loss from charging a reservoir will be non-existent, and convenience will be optimal, especially if you don't run that often. That and it's suitability for the larger boats may be the upside of using it. Especially when it's only for the backup and you use air induction through your snorkel mast at PD to surface, like a real combat sub.
Total Grams 160
Cost per Gram $0.11
Density g/CC 1.25
Cost/CC $0.13
Expansion Ratio 535
Cost per Blow $0.25
Total Grams 368
Cost per Gram $0.08
Density g/CC 0.91
Cost/CC $0.07
Expansion Ratio 306
Cost per Blow $0.24
Total Grams 1020
Cost per Gram $0.04
Density g/CC 1.24
Cost/CC $0.05
Expansion Ratio 274
Cost per Blow $0.19
