ICTINCO ll Submarine Build
  • Scott T
    • May 2009
    • 414
    #106
    Shows a solid prop on video.
    Also picture seems to show solid prop.
    Click image for larger version  Name:	fetch?id=168950&d=1668556729.jpg Views:	0 Size:	93.9 KB ID:	169531
    Click image for larger version  Name:	ictineo prop on model.jpg Views:	0 Size:	40.1 KB ID:	169530.
      Sorry Folks! If you look at the old original actual photos out there you will see the split angled two sided prop. I am sure that the RC model you show has a two bladed prop similar to an aircraft propeller. Thank you very much for your input!
      Honestly, I am really not interested in trying to make this boat totally operational. I do have a WTC installed and it is operational! (check my blog) Also the print files for this boat were for a 22" plus cut-away static model, not for RC operation. I built the Ictineo ll, the Turtle (not operational, and which will be finished today) the HL Hunley, the HMS Holland, and the SM UC 5 U-boat (which are RC operational boats) just for the historical and a certain time period of submarine development.
      Moving on to my next series of projects!!
      "Firemen can stand the heat."
        Last Photo! Notice the prop blades!
Name:	ICTINEO ll 77.jpg
          • Oct 2017
          • 1100
          #109
          Last comment. This is the bare hub.the blades are missing
Name:	ICTINEO ll 78.jpg
Name:	ICTINEO ll 79.jpg
ID:	169541Click image for larger version
Name:	ICTINEO ll 80.jpg
            I built this boat as per plans and photos! If I am wrong, I am wrong! So be it! Over and out!
