ICTINCO ll Submarine Build
    Tonight I have been working on the design for the rudder control linkage on the Ictineo ll.
    Click image for larger version  Name:	ICTINEO ll 36.jpg Views:	0 Size:	54.5 KB ID:	168106Click image for larger version  Name:	ICTINEO ll 35.jpg Views:	0 Size:	56.5 KB ID:	168107
    What you see here is my printer printing out individual chain links that will become the two chains that will control the rudder actuation.
    Click image for larger version  Name:	ICTINEO ll 37.jpg Views:	0 Size:	56.2 KB ID:	168108
    This is not the first time that I have 3D printed these chain links. I used them on my Holland build. They are a little time consuming to put together, but they are extremely strong and will work great as the (pull/pull) system for the rudder on the Ictineo ll boat!
    "Firemen can stand the heat."
      • 3673
      #62
      Look for scale chains meant for 1/16 RC armoured vehicles or you could use cheap jewelry chains which come in different sizes.
        Thanks Romel,
        Appreciate your input, but going to try this first! Besides the chain links are a blast to put together! :-))
          Today I started with installation of the two MG90 9g servos.
Name:	ICTINEO ll 38.jpg
ID:	168120Click image for larger version
Name:	ICTINEO ll 39.jpg
          I have opened up the slots on both the starboard and port side of the stern section. I will be designing and fabricating brass frames around these openings. I have also got a good start on fabricating the pull/pull chains that will operate the rudder!
            Tonight, I found a little time to work on the rudder servo (2) installation.
Name:	ICTINEO ll 40.jpg
ID:	168167Click image for larger version
Name:	ICTINEO ll 41.jpg
Name:	ICTINEO ll 42.jpg
ID:	168169Click image for larger version
Name:	ICTINEO ll 44.jpg
            I fabricate 2 copper servo arms from copper tubing to add some Strength to the arms. The final length's will be determined after I install the chains from the rudder up to the servo arms. The rudder servos are just temporally installed at this point!
              • 3673
              #66
              Click image for larger version  Name:	ictineo_001.jpg Views:	0 Size:	71.4 KB ID:	168176
              On the outdoor display of the Icteneo the rudder chains pass through a slot in the stern and are actuated inside the hull. You could use a single servo with twin control horns instead of 2. You could put a spring or elastic band between the chain and servo horn to put tension on the chain.
                Great idea Romel!
                Problem is I do not have the room in the stern section to install the servo as you have drawn! But using the same two mini servos and installing the servo arms to the inside of the stern hull I may be able to accommodate the basic same design! Thanks for the drawing! (Honestly I did not like my design either) :-)) Stand by!!
                  OK! Romel (redboat219)
                  I took your advice as for concept. I designed my stern section to allow for your concept! "BINGO"
                  https://youtu.be/GDGymBHH_m4
                    • 3673
                    #69
                    We use to have a cuckoo clock that utilized falling weights to power it. The weights were attached to small chains that went around a sprocket wheel. Click image for larger version
Name:	images (1) (7).jpg
                    If you could get your hands on one these sprockets or 3D print one it would be a good alternative to the servo arms. Click image for larger version
Name:	images (1) (8).jpg
ID:	168201Click image for larger version
Name:	images (1) (9).jpg
                      We use to have a cuckoo clock that utilized falling weights to power it. The weights were attached to small chains that went around a sprocket wheel. Click image for larger version  Name:	images (1) (7).jpg Views:	0 Size:	42.4 KB ID:	168200
                      If you could get your hands on one these sprockets or 3D print one it would be a good alternative to the servo arms. Click image for larger version  Name:	images (1) (8).jpg Views:	0 Size:	45.8 KB ID:	168201Click image for larger version  Name:	images (1) (9).jpg Views:	0 Size:	22.5 KB ID:	168202
                      Thank you Romel! (Make it simple, make it strong, make it work!) But thank you for the suggestion!
                      I think this qualifies! https://youtu.be/GDGymBHH_m4
                        "Happy New Year" Everyone!!
                        Today I finished up the installation of the two MG90 mini servos (water proofed) using mineral oil.
Name:	ICTINEO ll 46.jpg
ID:	168209Click image for larger version
Name:	ICTINEO ll 45.jpg
                        https://youtu.be/NdfoMxsCdEo
                        The rudder system using two MG90 mini servos and 3D printed chain for the rudder operation is now complete! After lots of trial and error the system that I have works very well and should give the rudder lots of throw. I am now going to move onto the mounting the stern section to the rest of the hull making it removable of course if repairs are required!
                          Tonight, I worked on the brass mounting plates that I will be using to mount the stern section of the hull to the main hull!
                          Click image for larger version  Name:	ICTINEO ll 47.jpg Views:	0 Size:	55.6 KB ID:	168240Click image for larger version  Name:	ICTINEO ll 48.jpg Views:	0 Size:	50.1 KB ID:	168241
                          Click image for larger version  Name:	ICTINEO ll 49.jpg Views:	0 Size:	54.2 KB ID:	168242
                          I used brass screw inserts to secure the brass hold down plate. I first drilled out a hole just shy of the diameter of the brass insert. Then I used my heated soldering to heat up the insert so that it would melt the PLA as I pushed into the hole. This method is extremely effective over the use of CA! Installing the brass hold down plates on the outside will just enhance and blend in with the other hatches that are on this boat.
                          NOTE: THIS IDEA MAY CHANGE!! AND IT DID!! SEE NEXT POST!!
                            OK! I definitely made a change to the original stern section hold down system!
Name:	ICTINEO ll 51.jpg
ID:	168252Click image for larger version
Name:	ICTINEO ll 50.jpg
                            I installed 3 3D printed tabs and secured them to the main hull, 2 on the side and 1 in the top. I install brass threaded bushing so screws through the hull can be used to secure the stern section! Much cleaner looking and a better securing fit!
                              Tonight, I finished up the stern section hold downs, reinstalled the drive motor, and installed the rudder and drive chains (2)!
Name:	ICTINEO ll 52.jpg
                              This photo shows the chains installed to the horns temporally. I may move them a little more towards the center.
                              https://youtu.be/VZ1wMUiFdxE
                              The video shows the movement I am getting at this point. With a little more adjustment I may even get more. But for as bulky and heavy that this boat is and the weird prop for propulsion, I do not think this boat will be a shaker and a mover in the water! Thats OK! I have achieved what I set out to do to this point. I have more work to do on the WTC and radio system.
                                Progress report on the Ictineo ll.
Name:	ICTINEO ll 53.jpg
ID:	168344Click image for larger version
Name:	ICTINEO ll 54.jpg
                                The stern section (propulsion and rudder) and the stern section hold downs are complete. Next in line is to complete the WTC and the electronics. As noted before this boat will operate in the water, but the boat itself is exceptionally heavy and with the current (to scale) propulsion system it will most likely not move at all, let alone have any rudder authority. I will certainly settle for that and at least have a scaled up full radio controlled model!
Name:	ICTINCO ll 3.jpg
                                While I am finishing up the scaled up version of the Ictineo ll, I will begin 3D printing (300 parts) the model as it was designed for. A 20.5" long 4.8" high cut-a-way with a fully detailed interior. In my opinion having fully operational scaled up model and the cut-a-way model together will make an interesting display.
