British submarine id
    Swiftsure class:
ID:	64205Click image for larger version
Name:	hms sceptre.jpg
ID:	64206Click image for larger version
Name:	hms sceptre1.jpg
ID:	64207Click image for larger version
Name:	hms spartan.jpg
ID:	64208Click image for larger version
Name:	hms splendid.jpg
ID:	64209Click image for larger version
ID:	64210Click image for larger version
ID:	64212Click image for larger version
ID:	64213Click image for larger version
ID:	64214Click image for larger version
ID:	64215Click image for larger version
ID:	64216Click image for larger version
ID:	64217Click image for larger version
Name:	ssn sovreign.jpg
ID:	64219Click image for larger version
ID:	64220Click image for larger version
ID:	64221Click image for larger version
ID:	64222Click image for larger version
          As you can see , over the years changes were made to their sails , showing the addition of new equipment.
          Next up, Trafalgar class.
            • 13572
            #80
            Man! ... this is good stuff. Thanks.
              Thanks Dave. I love it when a plan comes together..........George Peppard.............A-Team
                Just a note on the difference in appearance Anechoic tiles can have on a submarine. Note this early picture of a Swiftsure class and note the clean appearance of the hull and sail.
                Now note this Swiftsure class after tiles were applied. You can see how they obviously didnt put them over the sail windows and sonar windows. Notice also how much thicker the sail tiles are than the hull tiles..
ID:	64658Click image for larger version
                  TRAFALGAR class
                  An upgraded Swiftsure class, there were seven (7) boats constructed. They were: Talent, Tireless, Torbay, Trafalgar, Trenchant, Triumph, and Turbulant. The HMS Trafalgar was the first to be ordered on April 7th, 1977. In 1990 HMS Trenchant hit the headlines when she got caught in the fishing net of a vessal named Antares. The submarine was unawares until it had pulled the fishing boat under and drowned four of her crew.
                  After twelve years of service Trafalgar underwent her first refit, including refueling her reactor. In 1998 she was then fitted with Tomahawk. A newer version called tacom is now torpedo tube launched and can loiter in the area for up to four hours before final targeting info must be uploaded. They also UNBELIEVABLY cost half the money as the old system.
                  During 1999 Trenchant was painted in a disruptive blue two tone paint job to make her less visible in shallow waters. It has not been repeated on the other boats. In May 2000 HMS Tireless suffered a primary coolant leak in her reactor system caused by hairline cracks. It was then discovered that all the rest of the Trafalgars as well as the Swiftsures had the same fault. They have since been corrected.
                  The bad news is that there is no visible difference between the Trafalgars and the Swiftsures.
                  Pictures to follow
                  280 ft. long
                  32 ft. 1" beam
                  One PWR reactor producing 15,000 SHP powering one pump jet propulsor
                  32 Knots submerged
                  Five 21" torpedo tubes
ID:	64676Click image for larger version
ID:	64677Click image for larger version
ID:	64678Click image for larger version
ID:	64679Click image for larger version
ID:	64680Click image for larger version
ID:	64681Click image for larger version
ID:	64683Click image for larger version
Name:	hms talent.jpg
ID:	64684Click image for larger version
Name:	HMS Talent periscope.jpg
ID:	64685Click image for larger version
Name:	Hms Talent thru seas.jpg
ID:	64686Click image for larger version
Name:	hms tireless1.jpg
ID:	64687Click image for larger version
Name:	hms torbay.jpg
ID:	64688Click image for larger version
Name:	hms trenchant.jpg
Name:	hms triumph.jpg
ID:	64690Click image for larger version
ID:	64691Click image for larger version
ID:	64692Click image for larger version
ID:	64693Click image for larger version
ID:	64694Click image for larger version
ID:	64695Click image for larger version
ID:	64697Click image for larger version
Name:	trafalgar class1.jpg
ID:	64698Click image for larger version
ID:	64699Click image for larger version
ID:	64700Click image for larger version
Name:	triumph and astute.jpg
ID:	64701Click image for larger version
                            Next up...........UPHOLDER
                              The Upholder represented a return to Diesel electric propulsion after many classes of Nuclear British Boats. They were designated to replace the earlier Oberon class. A total of 18 were planned including a "Super Upholder" of increased dimensions. The proportions of the Upholders was more like the Swiftsure/Trafalgar boats with two forward decks and a single engineering space. They were designed to be super efficient with much automation and fewer crewmembers.
                              There were many technical problems to deal with which cost much time and frayed nerves and purse strings in the House Of Commons. After four were completed the rest were all cancelled. The four were put up for sale.
                              The Canadians showed much interest and after protracted discussions a figure of 610 Million (Canadian) Eight year lease package was agreed upon.
                              The four boats were named while in British service as :Unicorn, Unseen, Upholder, and Ursula. The became the Canadian boats respectively: Windsor, Victoria, Chicoutimi, Cornerbrook, in that order.
                              230 ft. long
                              24 ft. 11" Beam
                              (2) 4070 HP Diesels single shaft prop
                              12 knots surfaced
                              20 knots submerged
                              (6) 21" Torpedo tubes capable of firing Harpoon
ID:	64798Click image for larger version
ID:	64799Click image for larger version
ID:	64800Click image for larger version
Name:	Flash drive 2 940.jpg
ID:	64801Click image for larger version
Name:	Flash drive 2 974.jpg
ID:	64802Click image for larger version
Name:	Hmas chicotoumi.jpg
ID:	64803Click image for larger version
Name:	HMCS Victoria.jpg
