OTW Ballast tank sensors and tank size
  • Thorbrandr
    • Mar 2022
    • 153
    My thought had been not to bypass the sensor, just shift it, and maybe add another to be more tolerant of the down angle without overflowing into the front compartment.
    I did contact Bob at OTW. He called and we had a great discussion.
    Bob thinks the boat is too light, requiring too much ballast fill. His simple recommendation: a touch more ballast. Simply provide enough extra space in the tank that this is not an issue. This should not disturb the surface trim by much. It does mean that it will be possible to fill the tank to a significant negative buoyancy, so I will need to watch that. So far the safety blow on the tank has always worked when it looses signal, and the new battery lasts longer than I do when running it.
    Chris
    • Schmitty1944
      • Mar 2021
      • 147
      I knew my by-pass idea wouldn't work if it has the hole between ballast and dry area, I just didn't realize that they pretty much always have that hole already drilled. Moving the filled water probe either higher up or to the opposite end of the ballast tank is likely to cause at least some flooding of the dry area.
      A while ago there was some talk and research about a fine mesh membrane that would let air through that hole but not water, I'm not sure what became of that idea but it sure would be helpful in your case.
      I'm probably not the only one that really doesn't like the idea of a hole directly between a wet area (ballast tank) and dry area (pressure hull). I know it works well enough within the limitations that others pointed out. It just seems like it's asking for trouble with the only thing between success and disaster is a electronic circuit and probe to tell the pump when to stop. A mechanical float valve that would stop water from going through that hole would be a big improvement, or better yet a dedicated compartment to contain the displaced air from the ballast tank as it fills, either section off part of the pressure hull or it could be its own separate compartment outside of the wtc as long as it was below the surfaced waterline. A vent line from the top of the ballast tank to the bottom of this air pressure vessel would be the only connection to anything.
      Bob's (O.T.W.) solution will certainly work for you, at the expense of not having as much surfaced free board and of course you can always add some foam above the waterline to prevent it from going too negative in submerged trim.
      Jason
      • goshawk823
        • Oct 2010
        • 262
        Chris
        I'm glad you called him. He will always help with questions related to his products.
        • Thorbrandr
          • Mar 2022
          • 153
          Jason
          I am running out of room for loam above the waterline! UPS scrambled the ballast, so it has taken a bit to get it sorted out. Overall I am getting very good performance now after adjusting for a tendency to drop the stern while submerged. I can deal with a little loss of freeboard on the surface - it actually runs pretty close to photos of the originals.
          Chris
          • Thorbrandr
            • Mar 2022
            • 153
            Actually, he called me! I had my contact info in the email I sent. Since he went paid me the courtesy to call, I figure I should trying his suggestion in my test tank this weekend and letting him know how it worked.
            Chris
            • Lupomen
              • Nov 2025
              • 8
              I'm hoping this thread is still viewable, sadly Bob passed away last Sunday, he was a very nice guy ! Onto my problem, my pump controller has flooded the electronics and I'm assuming will be U/S, given that OTW ones will ne longer be available, what alternatives might there be on the market for a sensor probe tank ? Newbie so be gentle LOL ! Paul.
                • 2584
                I believe the boards were purchased from a third party, so they may be able to help. Alternatively, the electronic board was I believe a through hole component based item, which lends itself better to repair if it's bit the dust. There is probably a microcontroller, and that is likely to have bespoke software, so if that is kaput then the company that made it is probably your only option for that board.
                If you need more volume an alternative approach is to cap the hole that vents the air into the dry space, ignore the sensor, then use a snorkel vent to use the full volume of the tank, and just use a simple bidirectional esc to control the pump.
                Don't know if OTW will rise again, but their website is already down.
                  • 865
                  Bob Dimmick sadly now deceased had or has still a OTW tech representative in the United States. I don't know his status now but he is completely knowledgeable on the OTW dive modules and its original specs.
                  Send me a private message and I will forward his contact information.
                    • 2026
                    It may be that the controller is still completely viable. The outer plastic can be stripped and the board scrubbed with a soft toothbrush and alcohol. I've brought a lot of boards back from the dead with this technique.
                    Aside from OTW's units, I'm unaware of a replacement unit that would be plug n play to replace it.
                      • 2584
                      I always thought that an exclusive bit of electronics was a bit of a red flag in that system. Most other ballast systems can use mass produced electronics, but the OTW unit needs special circuitry for the tank probes to prevent them corroding/plating up in water, aside from that it’s just a bidirectional motor control with solenoid actuation and I think there’s also a fail safe built in. That functionality at least can be easily found in other units.
                      • Lupomen
                        • Nov 2025
                        • 8
                        Thanks all I guess the functionality I would have liked was some form of stop mechanism at the tank full limit as the air bleed hole above that level is what caused me to lose the submarine !
                        Good wishes
                        Paul.
                        • neitosub
                          • Nov 2021
                          • 157
                          I would just convert it to a vented ballast with an air hose, pipe the displaced air to the surface via a conning tower snorkel and trim the submarine with slightly positive buoyancy when submerged.
                          • Lupomen
                            • Nov 2025
                            • 8
                            Thanks I'm going to do just that, I have ordered a snorkel I can conceal from Bob. How easy is it to drill and tap acrylic tube as I can only get to one side of the tank face so don't have the luxury of a nut on a pass through fitting ? For snorkel vent.
                              • 2584
                              Easy to work, but acrylic can be brittle. Start with a small drill bit and work your way up in small increments to the size you want and take it steady. You can work dry, although a little water mix with some soapy suds brushed on the work piece doesn’t hurt.
                              • Lupomen
                                • Nov 2025
                                • 8
                                #30
                                Many thanks. Paul.
