OTW Ballast tank sensors and tank size
  • type7
    • 198
    #31
    Easy to tap and drill. I added a drain plug to mine after coming home with a half filled tank once.
      Drain plug is a great idea, provided you can ensure a positive seal after repeated use.
        • 2639
        #33
        If using a threaded fitting you could wrap some PTFE tape around the thread.
