HMS Holland 1 - 3D CAD model in the making
  • DrSchmidt
    • Apr 2014
    • 1332
    #31
    Worked a bit on the manual actuator for the main friction clutch....
    • DrSchmidt
      • Apr 2014
      • 1332
      #32
      Completed the thrust block, two axial bearings, and the two dog-bone clutches....that's about it with respect to the drivetrain.
      Click image for larger version  Name:	Holland-023.jpg Views:	0 Size:	48.2 KB ID:	184005
      • DrSchmidt
        • Apr 2014
        • 1332
        #33
        More work on the drive train and the auxiliary equipment. The air compressor and the main bilge pump didn't have their own motors but were driven by the man drive train. The feed to the pump and the compressor was accomplished by a bevel gear located at the upper main gear. The respective axis was tilted upwards and went through a friction clutch into two additional bevel gears that drove the drive axis of the auxiliary equipment. There were dog-couplings between the respective bevel gear and the pump and compressor. Those will be designed next....
        And: I'd need some help. I read that the bilge pump was a Marburg type pump built in the US. I couldn't find anything on that Company or type of pump. Does anyone have material or references on these pumps?
        • DrSchmidt
          • Apr 2014
          • 1332
          #34
          More work on the drive train and the auxiliary equipment. The air compressor and the main bilge pump didn't have their own motors but were driven by the man drive train.I designed the bilge pump (upper right) and the air compressor (lower left) with help of the Lambert plans and very limited additional info. There is one photo showing the edge of the pump and nothing about the compressor. So there is guesswork involved. For the compressor I lent the design of a steam driven compressor of a locomotive. Astonishingly the cylinders fit quite well in the contours shown in the lambert plans....
          Click image for larger version  Name:	Holland-028.jpg Views:	0 Size:	49.0 KB ID:	184486
          Click image for larger version  Name:	Holland-029.jpg Views:	0 Size:	55.1 KB ID:	184487
          • DrSchmidt
            • Apr 2014
            • 1332
            #35
            Progress on the clutch actuator mechanics for the bilge pump and compressor.....The pump and compressor were bolted to the outer hull. These mounts also acted as anchor points for the shafts and levers....intricate design.
            • DrSchmidt
              • Apr 2014
              • 1332
              #36
              More details on the actuation mechanics for the clutches of the bilge pump and the air compressor. The main clutch is a friction clutch and was actuated by the lever in the front. The individual dog bone clutches for pump and compressor were actuated by a shaft-in shaft assembly, with the upper lever actuating the clutch for the compressor and the lower one the clutch or the pump via push rod.
              Click image for larger version  Name:	Holland-034.jpg Views:	0 Size:	59.9 KB ID:	184552
              • DrSchmidt
                • Apr 2014
                • 1332
                #37
                That's it with the drive train, the compressor and the bilge pump. Quite a complex setup for 1901
                • DrSchmidt
                  • Apr 2014
                  • 1332
                  #38
                  Final detail on the drivetrain....the circulation pump., I guess for the cooling water. This little pump was driven by the Otto motor via two gear wheels that were connected to the gear on the drive shaft of the combustion engine.
                  • DrSchmidt
                    • Apr 2014
                    • 1332
                    #39
                    Placed the drive train and the axiliary equipment in the hull. Starts to look like a submarine from the inside. I refer to the open gears as "Crew men mincer".
                    • vital.spark
                      • May 2010
                      • 307
                      #40
                      Andreas, Do any of these early Hollands still exist that can be inspected?
                      • DrSchmidt
                        • Apr 2014
                        • 1332
                        #41
                        Actually the H.M.S. Holland 1 still exists, hen it was towed to the breakers yeard in 1913, it sank. It was rediscovered years later, raised, restored and is now on dsply at the National Roayl Navy Musem in Gosport
                        When you step aboard Holland 1 you'll get a glimpse of what it would have been like to live and work aboard the Royal Navy’s most experimental and cutting-edge technological innovation of 1901. Discover the significant impact Holland 1 has on the Royal Navy and how she was a pioneer that revolutionised naval warfare. Unfortunately, it wasn’t all glory for Holland 1 as the boat sank in 1913 while being towed to breakers yard. Holland 1 was recovered in 1982 and has since undergone an extensive programme of conservation to preserve this significant vessel.
                        • DrSchmidt
                          • Apr 2014
                          • 1332
                          #42
                          Progress on my 3D CAD model of the H.M.S. Holland 1, the first submarine of the Royal Navy. After completion of the drive train I designed the buoyancy tank in the center section of the boat. It was embedded between the forward and the aft battery tank and the auxiliary ballast tanks on port and starboard. Above the tank were the hand wheels for the Kingston valve operating the tank and some manifolds. All that was located below the floor, and I haven‘t found out yet how they were accessed for operation. Any idea?
                            • 1936
                            #43
                            Andreas,
                            Is this by chance the boat you are modeling here?
Name:	HMS HOLLAND 154.jpg
                            Your model is going to be another one of your fantastic masterful builds for sure!
                            "Firemen can stand the heat."
                            • DrSchmidt
                              • Apr 2014
                              • 1332
                              #44
                              yes, that's the one
                                • 1936
                                #45
                                yes, that's the one
                                Thank you, Andreas,
                                They did look somewhat similar. I am sure the person that did the STL files took some liberty in his design as to its authenticity. Looking forward to seeing your finished build. Thank you for posting up all the great progress photos. I really enjoy following all your builds.
