HMS Holland 1 - 3D CAD model in the making
    • 1372
    A bit of progress on my old Holland project.....still working on the Otto Motor, that has much more in common with a steam engine than with a modern combustion engine, e.g. the revolution speed was controlled with a centrifugal governor.
      • 1372
      More bits, parts, levers....
        • 1372
        Some more pipes and plugs....
          • 2026
          Absolutely gorgeous work!
          • gantu
            • 420
            This is an nice video.
            Holland1 Submarine 1902 - 1913 (work-in-progress)
            Regards Gantu
              • 1372
              That's great input. Thanks allot. It also shows, that I understood the working pinciple correctly...
                • 1372
                The Otto motor is pretty much done. Some bolts and nuts here and there, but basically that's it....
                Click image for larger version  Name:	Holland-012.jpg Views:	0 Size:	55.0 KB ID:	183518
                Click image for larger version  Name:	Holland-013.jpg Views:	0 Size:	51.3 KB ID:	183519
                Click image for larger version  Name:	Holland-014.jpg Views:	0 Size:	52.1 KB ID:	183520
                  • 1372
                  Fits into the hull....
                    • 1372
                    Compared to the combustion engines, the electric motors are usually quite boring. Not the 1903 version with cast iron frames and open design. Note the upper gear axis running through the octagonal frame with the field coils....
                    Click image for larger version  Name:	Holland-016.jpg Views:	0 Size:	68.1 KB ID:	183699
                      • 1372
                      Added the brushes of the commutator. This is guesswork. I couldn't find a reliaibale source that shows how they looked. But on the original motor one can see interfaces that might have been the anchor points of the brush supports. Went from this idea....If you have more informatioj on this topic, Id be happy to adjust the concept.
                        • 2581
                        Will you also be including the organic CO detector?
                          • 1372
                          Maybe, maybe.....but for now I concentrate on hardware, not wetware.
                            • 1372
                            Progress on the drive train. One has to appreciate the compact design, where the frame of the electric motor also supports the gears. The gear on the Otto motor side has a friction clutch. When engaged, the upper shaft is coupled to the combustion engine and drives the prop and the electric motor as dynamo. When open, the electric motor drives the upper shaft via the rear gear. Clever! But: The coarse and spur-toothed gears without housings must have caused a hell of a noise. And no noise suppression bulkhead between engines and crew....
                              • 2581
                              I expect they were too high as kites on the petrol vapours to care about the noise.
                                • 1372
                                #30
                                Progress on the drive train of the HMS Holland....I detailed the gear and the clutch. The clutch again is allot of guesswork. The original corroded to a large extent and the Lambert plans are not detailed enough to compensate. But I found some photos of vintage steam engine pulleys with friction clutches that look very similar to what I can see on the Holland photos. So I went with that....
