HMS Holland 1 - 3D CAD model in the making
  • DrSchmidt
    • Apr 2014
    • 944
    So I got this nice Plate 1 and the usable copy of the John Lambert plan (thanks Jason for that!). I'll try to create a 3D CAD model of the HMS Holland in a way, so that I can make a cut-away display model in 1:35 scale of it. Started with the slightly sharper Plate 1 and so far I have the spindle-shaped hull with their L-frames.
    • 1819
    Andreas,
    Looks like you have found a 2D plan that will work to create your model of the HMS Holland 1! I am sure looking forward to this build!
      • 2126
      That's sheet 2 of the John Lambert plan.
      You can get a full copy from-
      Designer: John Lambert Star Rating: *** Very detailed external and internal drawings of the Navy's first submarine drawn at 25.5in length. The drawings are very detailed and annotated and make interesting study in addition to their value to a modeller. No model construction details are included. Please note that all plans are printed to order […]
      • DrSchmidt
        • Apr 2014
        • 944
        Excellent…. that's what I was looking for.
        I ordered the plans, and if they are good, I'll get them scanned and then I'll work of them. Better than internet material, no matter how good it is...
        So I'm putting a hold on the project till the plans are here.
        Cheers Andreas
        • DrSchmidt
          • Apr 2014
          • 944
          Took a while, but thank to the nice hint by Mr. Subculture I got hands on the John Lambert pans of the HMS Holland, got them scanned and now I'm good to go....
          Click image for larger version  Name:	Holland-003.jpg Views:	0 Size:	71.6 KB ID:	166731
          • DrSchmidt
            • Apr 2014
            • 944
            Getting the bulkheads and floors done....
            Click image for larger version  Name:	Holland-004.jpg Views:	0 Size:	68.0 KB ID:	166790
            Click image for larger version  Name:	Holland-005.jpg Views:	0 Size:	90.6 KB ID:	166791
            • DrSchmidt
              • Apr 2014
              • 944
              More progress on the internal structure....
              • DrSchmidt
                • Apr 2014
                • 944
                And some more....
                • DrSchmidt
                  • Apr 2014
                  • 944
                  Nice Sunday aftrenoon....some European League Football and drawing the Otto-Engine of the H.M.S. Holland
                  • DrSchmidt
                    • Apr 2014
                    • 944
                    Slow progress...
                    • DrSchmidt
                      • Apr 2014
                      • 944
                      I ran into this excellent 3D model of the HMS Holland by Mark Alloway:
                      Old model that I’ve redone using the Filmic color management settings and the new Principled shader.
                      As I'm missing source material for the Engine I contacted him to learn where he got his information. He was very helpfull, and I'm happy to say, that I got some very accurate drawíngs of the Otto engine . That's a big differenece,....
                      • DrSchmidt
                        • Apr 2014
                        • 944
                        Working of good drawings makes a huge difference....
                        • DrSchmidt
                          • Apr 2014
                          • 944
                          Some more progress on the valve covers and the cam shaft supports.....
                          • DrSchmidt
                            • Apr 2014
                            • 944
                            A bit of progress on the Otto motor of the HMS Holland. Some rocker levers, valves and retaining springs.
                            • DrSchmidt
                              • Apr 2014
                              • 944
                              Som emore details, drives, cam shaft....the position of the rocker levers with respect to piston posiion is approximated....
