Japanese Sen Toku I-401 Submarine Build
    • 1770
    #76
    I have done a rough final sanding on the hull.
    Click image for larger version  Name:	i-401 sanded.jpg Views:	0 Size:	78.1 KB ID:	155839 Click image for larger version  Name:	i-400 grunge look.jpg Views:	0 Size:	70.2 KB ID:	155841
Name:	i-400 grunge 3.jpg
    After going over actual photos of the i-401, it is not the finest bit of craftsman workmanship as far as full scale submarine building goes. The Japanese where in a big hurry to get the i-400 class subs in the water, and did not put a lot of fine finish work on these boats.
    Therefore some imperfections in my workmanship will just enhance the overall look of this model.
    • coryhenry
      • Jul 2020
      • 156
      #77
      I have started on the super structure (sail) detail items. The deck guns have will not print out on a standard 3D printer at the scale I need! I will be fabricating the smaller guns using parts and pieces from different types of guns to achieve a reasonable facsimile to the full scale!
Name:	i-401 deck guns 2.jpg
ID:	155758Click image for larger version
Name:	i-401 deck guns.jpg
      I will be using TinkerCad to achieve what I need!
      Do you have a resin printer for the guns?
        • 1770
        #78
        No, I do not have a resin printer. I was able to locate some parts and pieces on Thingiverse and print them, and then with some cutting, sanding, and a little TinkerCad I was able to replicate the 25mm deck guys pretty darn close. Close enough for government work!
          • 1770
          #79
          I have been working on the superstructure/sail. I have started on fabricating the antenna and the other array of equipment.
Name:	i-401 Sail 3.jpg
ID:	155918Click image for larger version
          I will be adding the adding the rails to the sail as well as the main deck. I will be using TinkerCad to design the railing and they will be 3D printed!
            • 1770
            #80
            I have the railings manufactured and installed on the superstructure/sail!
Name:	i-401 railings 2.jpg
ID:	155953Click image for larger version
Name:	i-401 railings 4.jpg
            I still have a considerable amount of fine tuning on the superstructure, but it is about ready for the priming stages. I will be moving next to the hull upper deck railings next!
              • 1770
              #81
              I am working on the stern dive plane guards tonight.
Name:	i-401 stern 1.jpg
ID:	155981Click image for larger version
Name:	i-401 stern 2.jpg
              I am having to fabricate these from some square plastic stock that I have. There are a lot of items on this build that are being scratch built because the 3D printer just could not make them correctly! No Problem!! I am enjoying the building process on this boat!
                • 1770
                #82
                The i-401 Sen-Toku construction is complete!
Name:	i-401 fimished 3.jpg
Name:	i-401 finished.jpg
                All I have left to do is some final sanding and cleanup work, and then the final finish work itself!
                After going over all the original photos of the full-scale boat (thanks to those for posting a lot of the photos) I am going to do the final finish in more of a rustic look!
                • Sam Victory
                  • Sep 2021
                  • 391
                  #83
                  I've always been troubled by one question: what exactly is the crane structure on the I-400 submarine? I have thought of various structures to realize the crane retraction, rotation and hook retraction. But given the paucity of information on the I-400 submarine, I still don't know the real structure of the crane. The real structure may be very simple, but unfortunately, the reference pictures are either too vague or simply too few.
                  Click image for larger version  Name:	6ecc6a714e872ffbf224f5d02fa0932.jpg Views:	0 Size:	93.0 KB ID:	156040
                  Click image for larger version  Name:	微信图片_202110271519432.jpg Views:	0 Size:	65.6 KB ID:	156041
                  I-14:
                  Click image for larger version  Name:	I-14.jpg Views:	0 Size:	78.8 KB ID:	156042
                  I-400:
                  Click image for larger version  Name:	cf6c7807239f66ced4b0c79aa38b4c8.jpg Views:	0 Size:	63.0 KB ID:	156043
                  Click image for larger version  Name:	diagram.jpeg Views:	0 Size:	97.2 KB ID:	156044
                  V
                  • KumaDog
                    • Sep 2021
                    • 36
                    #84
                    How about for retrieving the aircraft after their mission?
                    • Sinksalot
                      • Mar 2020
                      • 332
                      #85
                      This is looking good, keep up the good work.
                        • 803
                        #86
                        Very nice work Rob. That has been quite a project for sure.
                          • 1770
                          #87
                          Thank you, Sam for the new photos! They just re-a-sure me that a more rustic look will be the final finish!
                          Hi Steve, and thank you for your compliment! The crane reference, it was used to retrieve the aircraft after their mission! After locating the i-401 on Thingiverse, and doing some CAD work to re-size and re-a-just some of the pieces, a long with scratch building other structures, it has been a real learning process! The most I got out of this project was not only the building, but reading the history on the i-400 class boats!
                            • 803
                            #88
                            My 16 year old son is enamoured with the I-400. He wants one bad in 1/48th scale.
                              • 1770
                              #89
                              That's great Steve! It's really nice to see you and your son working together in this hobby. Cherish that special time with him Steve!!
                              The i-401 that I found on Thingiverse was about 6' long at 100% build size! My Dremel of course could not handle that size and that is why I sized mine down! You might check out the files for the i-401 on Thingiverse, you might be able to use their files!
                                • 1770
                                #90
                                I have started off with a slight darker grey primer on the i-401.
Name:	i-401 primered 2.jpg
ID:	156066Click image for larger version
Name:	i-401 primered.jpg
                                I will use this color to build off the rustic look that I am looking for!
