Russian Alfa Class
    Originally posted by neitosub
    Hi Rob,
    Yes, you can wire the motor to the ESC as per your picture. If you notice the motor rotating in the wrong direction when going forward, simply swap any of the two wires and reconnect them to the ESC. I usually keep the center motor wire connected to the B wire on the ESC and swap around the other two.
    Nate
    Thank you very much Nate,
    I really appreciate all your advice and help on my Alfa sub project.
Name:	SCRATCH BUILD HEX COPTER 1.jpg
    Prior to building submarines my passion was scratch building and flying quad, and tri-copters. Running brushless motors and the ESC's on submarines seems to be the same, except for the environment.that we operate them in. So for me a little refresher course and help does give me a little re-assurance that I have not forgotten everything.
    Thank you Nate, and others, for stepping up with advice and help!
    ​​​​​​​"Firemen can stand the heat"
  • neitosub
    Hi Rob,
    Nate
    OK! The motor end wiring is done!
Name:	ALFA MOTOR 1.jpg
    I do have a question about the ESC wiring to the motor!?
Name:	ALFA MOTOR 2.jpg
    There are three wires coming from the ESC. They are marked A,B, and C and all black! The motor has three wires and they are Red, Black, and Yellow as per photo. Can I use the line up (hook up) as per the photo?
    OK! I changed my mind, and I am now going with a better design for the motor link ups!
Name:	ALFA STUDS 3.jpg
    I am using the motor wires and made loop and soldered them to form the connections. The copper studs were just to big and bulky!
    Thanks Bob!
    Great idea, but as usual I did not have a tap that small. So, I drilled the hole for the brass screw slightly smaller and used the screw itself to make the threads. They screwed in great and formed a nice tight fit, I then backed them out and applied the medium CA to about center and screwed them back in followed by thin CA. It seems to be a good solid fit!
Name:	ALFA STUDS 1.jpg
ID:	161854Click image for larger version
Name:	ALFA STUDS 2.jpg
    I am manufacturing my own copper studs, and again it's because I did not have the right size for the job. I still have some shaping work to do on them before I solder on the wires from the motor on the wet side and the ESC on the dry side. Time consuming for sure, but it is fun to learn new ways of doing things!
    Thanks again for your help Bob!
    I'm sure David will chime in, but typically one would drill and tap the endcap and thread the stud into it. Wick some thin CA at the base and it will shoot down into the endcap and create your seal. You can also put a drop of thicker CA on the threads before you get to the desired depth, and then screw it into the endcap until the CA drop is well into the endcap material.
    Thanks David!
Name:	ALFA SQUARE 1.jpg
    I am back to square one! I am taking your advice and your design!
    Buy Hillman 1976 4-40 x 1-1/4 in. Round Slotted Machine Screw - Brass 24-Pack: Machine Screws - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
    I will be using the brass 4-40 studs to tie the power wires through the end cap to the motor! Thank you for your help on this!
    Ounce you have the stud or screw through the cap. How are to sealing them so that they won't leak? I could not tell if you are using rubber O-rings or not!
    Thank you for your help and advice!
    Originally posted by SubHuman
    Yes, a much better idea. The bullet connectors would, I think, be an easier solution, but the studs work well, too.
    Bob,
    This submarine building hobby sure is a REAL challenge! Just about the time you think your about to break through it knocks you down again! Working in the water environment just involves a whole new set of rules and building challenges!
    Thanks for all your help and advice Bob! Give Jason my best! "Onward and forward is the line for today"
    Romel,
    Thanks for the photo!
Name:	images (12).jpeg
    Cable lugs.
    It's a bad idea.
    Water is tenacious and will work its way through the wires.
    Install three pass-through brass studs (4-40 works for me) into the motor-bulkhead. Those are your conductors from the motor outside to the ESC inside.
ID:	161821Click image for larger version
ID:	161822Click image for larger version
ID:	161823Click image for larger version
ID:	161824Click image for larger version
ID:	161825Click image for larger version
    Thanks David!
    Originally posted by type7
    And here is where I say is sealing up 3 wires easier and cheaper than one cup seal on the driveshaft?
    Hi Bob,
    I totally understand what you are saying, but doing a complete redesign of the already existing WTC trays, plus install the motor to a secure hold down, this brushless motor makes good sense, because if you look at the motor alignment to the propeller shaft in my photos you will see a straight in shot to the shaft. This is an existing dual motor WTC that I am modifying to a single motor design for my ALFA boat.
    Also, if you have followed any of my other build blogs, you will see I like to do a lot of extermination in my building! That's part of the enjoyment that I get from this hobby.
    Nate, and all!
    This is what I had in mine.
Name:	ALFA MOTOR WIRE 2.jpg
    I do understand if the motor fails or the ESC that I would need to cut the wires and resolder again! After looking at the motor wiring I can see where the water might come from the motor wiring through the insulation and into the WTC! I am not as experienced as you guys by any means, so if you really feel this is a bad idea please tell me!
    It's a bad idea.
    Hi Rob,
    In that case just make sure that the solder joint between the ESC and the motor wires is sealed against the motor wire insulation. When in doubt, a quick dip inside the pool should reveal any potential leaks.
    Nate
    Nate, and all!
  • type7
