Motor Bulkhead/Cylinder Union Leak
    • Jan 2020
    • 1036
    #31
    So I still have a leak thru my bow endcap where water is getting past the O Ring. I sent it to Bob and he replaced the O Ring and added 3 wraps of teflon under it. I am not happy as it is again leaking. Maybe I need a thicker O Ring? The teflon tape is a pain and it just seems like there should be a more suitable fix. I have gone to sealing the endcap with Gasket Maker which works. If I need to access the electronics I can carefully use a hobby knife to cut the sealant at the cylinder union with the cap. Any ideas?
      • 13977
      #32
      Gut the electronics (keep the motor-bulkhead and it's attached devices there) and send me the cylinder with the offending bow bulkhead.
        • Jan 2020
        • 1036
        #33
        David, thankyou sooo much. Would it work for you if I wait till the end of the season to send it to you? I really appreciate you offering to take a look at it.
          • Jan 2020
          • 1036
          #34
          David, can you provide me your address? My email is biggsgolf@mac.com
            • 13977
            #35
            David D Merriman lll
            835 Holly Hedge Ave.
            Virginia Beach, VA 23452
              • Jan 2020
              • 1036
              #36
              David, just to clarify, it is the Stern endcap which fails.
                • 13977
                #37
                The one with the attached motor? That's the motor bulkhead. Send it along too.
                  • Jan 2020
                  • 1036
                  #38
                  Yes, the motor bulkhead, will do, thanks
                    • 13977
                    #39
                    OK, Your SD, the one you sent me for repair is a screaming pile of ****! There are many fatigue cracks in the cylinder, some bridge the internal bulkhead seals, causing leaking; that motor-bulkhead has been glued, screwed, and just plain abused to the point of uselessness. Why the **** would you glue the pushrod(s) to their respective seal bodies???!@!!!!!
                    Since what you sent me is so ****ed up, I made you a new one. Going out today. Live long and prosper, and all that happy horse-****.
                    In the future, you -- and those reading this ass-kicking -- If you have a problem with the new unit, something I produced and sold in working order, post your problem(s) here first so I can guide you so you don't screw things up.
ID:	151835Click image for larger version
ID:	151836Click image for larger version
ID:	151837Click image for larger version
ID:	151838Click image for larger version
ID:	151839Click image for larger version
ID:	151840Click image for larger version
                      • 13977
                      #40
                      Bruce:
                      I have your box ready to go, but the only address on the box you sent me was a UPS store. E-mail me your address as soon as you can so I can get this off to you today. dmeriman@aol.com
                        • 13977
                        #41
                        Bruce:
                        Never mind. I'm an idiot. You supplied your address... found it in your boxes packaging. Just got back from the USPS -- should be in your hands early next week.
