Motor Bulkhead/Cylinder Union Leak
    • 13973
    Dave, sorry, yes the O Ring seems to have a thin black bead all the way around, I was confused
    The video was useful. Yes, looks to be loose. But, again -- look at the cylinder over the O-ring: are there any cracks?
    • biggsgolf
      • Jan 2020
      • 1036
      There are a couple scratches that I can feel while running a flat blade across them and yes they extend across the O Ring.
      • biggsgolf
        • Jan 2020
        • 1036
        And on the inside of tube
          • 13973
          shallow scratches the O-ring can handle. Are you confident they are not fractures the extend to the outside of the cylinder? Look at these 'scratches' from all angles with a bright, single light source -- refraction will tell you if its a crack or scratch.
            • 3751
            Thanks Tom, so you put the teflon under the O Ring?
            Yes. From your video, It looks to me that your assessment that the air is getting past the o-ring is correct. If your o-ring does not have any nick or cuts in it and it did seal originally, it might be the resin shrank just a little and now the seal is not being made. Wrapping 4 - 5 times around the bulkhead o-ring channel with Teflon tape should tighten up that seal. Do not forget to re-grease your o-ring with silicon.
            • biggsgolf
              • Jan 2020
              • 1036
              Thanks Trout, Dave I will examine closely upon return to home base.
              • biggsgolf
                • Jan 2020
                • 1036
                Can anyone confirm the size O Ring is as pictured below? I replaced the original O Ring in may
                • biggsgolf
                  • Jan 2020
                  • 1036
                  • biggsgolf
                    • Jan 2020
                    • 1036
                    There are no cracks, I wrapped teflon tape around the encap, inspected the new O Ring, silicone greased the O Ring, Installed the O Ring into the channel. Still getting a small leak thru the O Ring...... what are my options? Getting tired of this constant issue.
                    • biggsgolf
                      • Jan 2020
                      • 1036
                      Hi all, after inability to negate the leak, Bob offered to take a look at it. I also had him ship back a new mini pump as the original rusted from the leak and was no longer functioning. Bob applied 2 Teflon wraps and a new O Ring, water testing was successful. I am now swapping the pumps. I did not realize the new pump did not include the outer board where power and servo is connected. Pain the butt, but it is working. My question is I assume I need to drill the two holes in the new pump which are present in the old pump? I assume thats how the pump gets air from within the cylinder to blow ballast?
                        • 13973
                        Back a few years ago the producer of those pumps tightened their QA and they stopped leaking past the pump proper. Those holes were weep-holes to carry away water from a leaking pump body. No longer needed on the improved product. Don't sweat it.
                        • biggsgolf
                          • Jan 2020
                          • 1036
                          Thanks David!
                          • biggsgolf
                            • Jan 2020
                            • 1036
                            Any pointers on:
                            1.) Best way to attach tubing to above mini pump to ensure it stays connected?
                            2.) Best way to replace a bulkhead O Ring and apply silicone grease?
                              • 13973
                              Any pointers on:
                              1.) Use flexible 1/16" i.d. silicon tubing and squeez it onto the pump nipple.
                              2.) Unscrew the fasteners holding the bulkhead within the cylinder; remove attached devices from bulkhead; pull the bulkhead and swap the O-ring; coat the inside of the cylinder with spray silicon, slide in the bulkhead and make fast with machine screws.
                              3.) Sing my praises!
                              • biggsgolf
                                • Jan 2020
                                • 1036
                                #30
                                Haha! Yes my lord! I praise thee
