Motor Bulkhead/Cylinder Union Leak
  • biggsgolf
    • Jan 2020
    • 1036
    Hi,
    I have a tiny leak where the Motor Bulkead Seals to the Cylinder.
    I replaced the O Ring, still a leak. My understanding is that the bulkheads are produced and matched to a cylinder.
    What options do I have? This is the USS Blueback, with the 11/2” Subdriver from Bob.
    I hear wrapping teflon tape around the endcap before putting in back into the cylinder helps.
      I assume you mean 2 1/2" cylinder? And is it the SD or MSD type? Is the leaking O-ring evidencing a solid black 'bead' when made up to the cylinder. If not it's loose?
      You might remove the O-ring, examine the groove and look for dirt or flaws in the channel. Insure the O-ring is clean and well greased.
      Keep me informed. We'll fix this!
      • biggsgolf
        • Jan 2020
        • 1036
        Yes, 21/2”. The leak does not exhibit a black bead, I will do as suggested and inspect the O ring and channel. It seems too easy to slide the bulkhead in, it is not as tight as it was originally?
        The teflon tape is an idea I have considered.
        • biggsgolf
          • Jan 2020
          • 1036
          • biggsgolf
            • Jan 2020
            • 1036
            The O Ring and channel are as should be... the fit seems loose, not as tight as the battery bulkhead. When I do blow test with the hose the bulkhead wants to push out of the cylinder. Maybe the cylinder expanded from my shop heat?
            Dave, any thoughts on yrying teflon tape? I hate the idea of it not being as should be without tape etc.
              I would not worry about using teflon tape. It helps a lot.
              That repair was done 7 or 8 years go and still works great.
                Post a bigger photo. OK, that's an SD type. Are there any hair-line cracks of the cylinder over the O-ring?
                • biggsgolf
                  • Jan 2020
                  • 1036
                  Thanks Tom, so you put the teflon under the O Ring?
                  Dave, sorry yes, SD type, no hairlines visible, will post larger photo, momentarily
                  • biggsgolf
                    • Jan 2020
                    • 1036
                    • biggsgolf
                      • Jan 2020
                      • 1036
                      Guys, just occured to me I should call it the motor housing cap, not bulkhead?
                        Motor bulkhead, damnit!... motor bulkhead!
                        • biggsgolf
                          • Jan 2020
                          • 1036
                          Hahaha, one of my most favorite quotes!
                          • biggsgolf
                            • Jan 2020
                            • 1036
                            Here is leak video uploaded to youtube
                            • biggsgolf
                              • Jan 2020
                              • 1036
                              Dave, sorry, yes the O Ring seems to have a thin black bead all the way around, I was confused
