What are the Best Glues to use on 3D PLA material
  • george
    • Dec 2010
    • 731
    I was wondering what the BEST glue to use to join parts together from a 3D printing of PLA material? I heard a brand name Plastruct Plastic weld is BEST. I have some and tried it on a scrap piece BUT after a day I was able to pry the pieces apart. Should that be possible OR is my bottle old?????
    • 2004
    I've never had issues with CA adhesives on PLA. The trick is to sand the mating surfaces first. With a perfectly flush set of faces, thin CA grabs permanently. If you have gaps, I like rubber-reinforced CA gel. I swear by Gorilla brand CA gel.
    In my experience, the PLA part will break before the connection will.
    • Groot689
      • Mar 2016
      • 135
      Thanks Bob for the advice. I have been wondering about this issue as well.
      • bwi 971
        • Jan 2015
        • 940
        Same goes for resin printed parts.
        Make sure they are fully cured, not sticky.
        Clean mating surfaces with IPA after sanding.
        Grtz,
        Bart
        "Samuel Smiles"
        • george
          • Dec 2010
          • 731
          Grtz,
          Bart
          What is IPA ??
            • 3692
            Originally posted by george
            What is IPA ??
            A good beer? LOL
            • Scott T
              • May 2009
              • 406
              Maybe Isopropyl alcohol????
              • george
                • Dec 2010
                • 731
                Thanks Scott T
                Thanks to ALL for your replies
                • Racer
                  • Jun 2010
                  • 3
                  I have used CA which works well.
                  But for the ultimate in strength, I use this.
                  You need a jack hammer to take something apart if you use this stuff.
                    • 3692
                    Reading the label I saw "Resists weathering and humidity" which in our environment it needs the definitive waterproof. However, I went to the site and here are more specs:
                    • Bonds: Hard Plastic, Styrene, PVC, Acrylic, Ceramic, Concrete, Fiberglass, Metal, Vinyl, Wood
                    • Tensile Strength: 3500 psi
                    • Color: Cream
                    • Waterproof
                    • Handling Time: 4-5 Minutes
                    • Set Time: 10-15 Minutes
                    • Cure Time: 24 Hours
                    • Temperature Range: -40°F to 200°F
                    http://www.itwconsumer.com/devcon-pr...C%2025%20ml-23
                    Very cool tip! Thank you.
                    • george
                      • Dec 2010
                      • 731
                      Hi Bob
                      Thanks for your advice on glues.
                      About the Gorilla glue CA Gel, does it specifically say on the tube that it has rubber in it? OR is that a special version of that glue?
                      • bwi 971
                        • Jan 2015
                        • 940
                        Yeah jackpot
                        "Samuel Smiles"
