today's work
Do you flush the brass parts after etching them with ferric chloride?Leave a comment:
great minds think alike:There is another trick to restore weld lines that might be even easier. You place masking tape left and right from the position you want to restore the weld, laving only a tine gap with the width of the weld line. Then you apply the putty, scrape it flat removing the excess putty and then peel off the tape. Easy....
