I came across a Bronco Type XXIII 1/35 kit. Im thinking of what diameter WTC to use. The beam is 3.4. Has anyone put a 3.0 WTC in one?
Bronco Type XIII 1/35
Thanks for posting the pics, your experience is invaluable. Your posts, advise and willingness to share has helped me and many other folks immensely. I have one of your old D&E Miniatures 3.5 WTCs. It has the adjustable ballast space and the conical wedge rotary valves. Still water tight and works perfectly. Its a testament to you engineering and modeling skills. Thanks again.Comment
On a serious note: Much appreciate the appreciation. Just passing on what others taught me. Glad to help. The end-game is to leave the field better than you found it.
The HorribleWho is John Galt?👍 1Comment
I'll throw in my WIP, https://forum.rc-sub.com/forum/build...nco-type-xxiii
Bottom line is, we are here to help you if you should need it.If you can cut, drill, saw, hit things and swear a lot, you're well on the way to building a working model sub.👍 1Comment
